Old 11-01-2007, 05:37 PM   #1
p2140 mac mini install question
OK so i have finally received everything i need to get started. I have a lilliput 29 touchscreen, core 2 dou mac mini, macpac, and carnetixs p2140. I swear, i have been searching for the last 3 days for every little bit of info to help me and its come down to this. For the screen, does it matter if i splice the car charger or house charger and connect it to the p2140? and what setting do i set the screen for on the jumpers seeing as i dont think its 5v im guessing 12v right.(sorry for the stupid question) second, for the mac mini ive already connected the macpac to the mac mini but on the p2140 what volts does it require, 18.5v or 20v. now with the jp4 setting, im guessing that the screen is 12v and the mac is either 20v or 18.5v so i wanna make sure i set it to configuration two?. im guessing that since i have a stock wrx my input voltage is 12 right? next, what does the acpi green cable do.. im guessing from what ive read that i can power a usb device from the brown but the what is the point of a p5v i always read about. sorry about the dumb questions but im putting everything in today and i just want to get these last kinks worked out. thanks in advance
nnomaeeht is offline   Reply With Quote
Old 11-01-2007, 07:12 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
Moved to the Power Supplies forum.
Your question is less Mac-oriented and more PSU-oriented.
1 - Splice into a molex HDD power connector (yellow wire is 12v).
2 - Set it to 12v output for the screen.
3 - 18v for the Mac Mini. I thought this was in the manual, but I didn't see it. It's int eh manual for the P1900, the P2140 predecessor.
4 - For the ACPI cable installation, you really should read the manual for the P1900.
Your questions aren't so much dumb as newbish. They show that you have done little or no research before diving in and purchasing parts.
I highly recommend slowing down and doing some planning of your install, including wiring, PSU configuration and how all this hardware you purchased works together.
From your questions, I'd suggest doing lots of research.
It sucks. It's boring. You have to weed through lots of useless crap. It's time consuming.
But you'll have an infinitely better understanding of what yuou are about to undertake. You'll also be better equipped to troubleshoot those niggling issues that invariably will crop up.
Good luck.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Mac mini (Intel) and CNX-P2140 atl MacCar 9 08-19-2007 12:26 PM
Mac mini install for my delivery car? haiphan02 MacCar 4 03-27-2007 06:31 PM
Overheating your Mac Mini - No problem! Bugbyte MacCar 14 12-08-2006 09:46 PM
P1900 alternative power supply for Mac Mini johnsin MacCar 25 12-07-2006 09:05 AM
Mac mini VW GTi Install itrends Show off your project 0 03-23-2005 05:04 AM
