Old 11-01-2007, 06:31 PM   #1
Power Sources - Best Application (I'm confused.)
So I have been reading around the power source area, and I am getting confused.
I want to be able to power my screen/laptop(used as carputer) and have them both power on with start up.
Additionally I'd like to be able to plug in my cell phone charger and have an extra outlet, just because.
So, why can I not find a quality 4 outlet inverter? Are there any downsides to having an inverter that keep most people from doing this? AND with the inverter can I still have the desired startup/shutdown that I'm looking for?
Thanks for the help guys... I just don't get why I see everyone doing DC to DC or complicated wiring...
ilovemyhonda is offline   Reply With Quote
Old 11-01-2007, 10:24 PM   #2
stealinfool's Avatar
Chance are that you will not be able to get an inverter to only be powered upon startup without some hacking. The reason people use DC/DC converters is because most of the converters have an ACC input, so it knows when the car is "powered" and can then supply 12VDC to the devices.
Inverter setup... DC>AC>DC... doesn't make much sense IMO unless its absolutely necessary.
the destruction of a person builds character
Previous install pics in 2k3 S10
Project CarPc V2
stealinfool is offline   Reply With Quote
Old 11-02-2007, 05:03 AM   #3
Neither darque nor pervert
DarquePervert's Avatar
Because inverters take up a lot more space than DC-DC units.
Because inverters are far more likely to induce EMI interference (aka noise) into your audio setup.
Because inverters generate heat, creating a potential fire hazard.
Because inverters are inefficient by the very nature of what they do.
Lastly, maybe because it's hard to find a quality four-outlet inverter.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 02:24 AM
List Of 5.1/optical Amps Canuck Car Audio 144 03-20-2007 12:34 PM
im confused with power supplies now :( flavor4real Power Supplies 14 10-25-2006 11:38 AM
Noise (from engine and other sources) HELP!!! sstylos Car Audio 6 09-20-2005 12:41 PM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 12:13 PM
