Old 11-04-2007, 11:56 AM   #1
mazda 6 carpc monitor stop
hi
i have carpc for mazda 6 and i connect the power wire in wrong way
red with black
black with red
it is stop work and see same smoke
what problem and what is part in borad need 2 change ??
Zo6om is offline   Reply With Quote
Old 11-04-2007, 11:57 AM   #2
power fault in carpc
hi
red with black
black with red
Old 11-04-2007, 12:50 PM   #3
Uhmm, you connected the power to ground?
CubanAffection is offline   Reply With Quote
Old 11-04-2007, 01:35 PM   #4
Raw Wave
TruckinMP3's Avatar
You need to replace at least the part that smoked.
I hope your soldering skills are good.
TruckinMP3
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 11-04-2007, 01:53 PM   #5
You connected the wires in the wrong way so more than likely you have blown the whole system so you will have to get new equipment sorry to tell you this.
BIGGKATT01 is offline   Reply With Quote
Old 11-04-2007, 04:49 PM   #6
Neither darque nor pervert
DarquePervert's Avatar
Quote: Originally Posted by Zo6om View Post
hi
red with black
black with red
The problem is that you applied power with reversed polarity....
Your power supply is toast, at the very least. It's possible the whole PC is reduced to a paperweight.
Rather than identifying wires by their color, it's a far better idea to refer to them by their function (+12v constant, +12v switched or ground).
Oh yeah. QUIT CROSSPOSTING!
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 11-05-2007, 12:12 AM   #7
yes only motor for open and close the monitor it is work
monitor screen off
Old 11-05-2007, 05:38 PM   #8
Raw Wave
TruckinMP3's Avatar
monitor screen off
Mostly when you let the magic smoke out of electrical components it is replacement time.
TruckinMP3
Read the FAQ!
Bench testing Carpc with Opus 150 and ATX power source...is it possible? bambam Power Supplies 1 01-09-2007 06:57 AM
How to power carPC from AC outlet buurin Newbie 16 11-04-2005 07:45 PM
P 1280 AND an inverter to power my carpc, make sense? Will Albers General MP3Car Discussion 0 05-24-2005 11:50 AM
Power up carpc in home czal Newbie 2 05-13-2005 12:23 PM
HELP on Using Inverter and UPS to power carpc davidbudi Power Supplies 10 04-27-2005 10:36 AM
