The MP3car.com Store
Thread Tools Display Modes
Old 11-15-2007, 04:29 PM   #1
Injector's CarPC Specs
My Photos: (2)
What will this circuit do?
a friend of mine made this circuit for me, it's supposed to keep the relay closed for 40 seconds after acc has been shutdown,
and it works great, until i put a current through 87 and 30 on the relay, then it immidiatly shuts down after acc is gone, for
some reason when power flows through 87 and 30 it drains the capacitors as well.
can anyone help me out here?
Scion CarPC
Injector is offline   Reply With Quote
Sponsored Links
Old 11-15-2007, 04:37 PM   #2
psyrex's CarPC Specs
psyrex's Avatar
Vehicle: 2002 Lexus IS300
My Photos: (1)
What's the component on the top left?
psyrex is offline   Reply With Quote
Old 11-15-2007, 04:43 PM   #3
My Photos: (2)
oo forgot to label that one, it's a transistor
Scion CarPC
Old 11-15-2007, 05:33 PM   #4
psyrex's Avatar
My Photos: (1)
Can you list the terminals on the relay (85, 86, etc) and what you have them connected to?
Old 11-15-2007, 07:56 PM   #5
My Photos: (2)
86 and 85 are the coil which get + and -, 87 gets a constant positive from a fused +, 30 goes to + on my power inverter
i'm using an audio system 2 farad capacitor, but this cap is only to the system will survive cracking.
Scion CarPC
Old 11-16-2007, 06:47 PM   #6
My Photos: (2)
well i found the problem, when acc is turned off, the line goes from positive to negative, which causes the caps to immidiatly loose the power in them, any way to combat this?
Scion CarPC
Old 11-16-2007, 08:06 PM   #7
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
Add a small diode in series with that resistor going to ACC.
XPort 1.24 -GPS port splitter, logger, and USB device resume fix
Curiosity is online now   Reply With Quote
Old 11-17-2007, 10:45 AM   #8
My Photos: (2)
will the resistor keep ground from flowing to the caps?
i have some of this at home will they work?
http://www.radioshack.com/product/in...entPage=search
Scion CarPC
Old 11-17-2007, 11:01 AM   #9
Curiosity's Avatar
My Photos: (3)
That will work fine. Put it before or after the resistor. You're not really getting ground. When you disconnect the source, the other circuits in your car that are on accessory are putting a heavy load on the cap, so it instantly drains. The diode prevents the current from reversing.
Actually, I don't think you need the resistor.
Old 11-17-2007, 11:08 AM   #10
My Photos: (2)
sweet, thnx for the help, just before posting here i decided to go check the 12volt for diode info and i found this
so should i place a diode on the constant positive going to the transistor as well? the part that confuses me is that i used a voltage probe which tells me if positive or negative current is flowing through the wire and as soon as i shutoff the key the probe says the current goes from positive to negative
Scion CarPC
Sponsored Links
vB code is On
Trackbacks are Off
Battery based tank circuit (tested) Ricky327 Power Supplies 241 02-13-2008 04:43 PM
2-second power on circuit needed nst6563 Hardware Development 7 11-05-2007 08:58 PM
Question about the Diodes used in Ricky's battery based tank circuit nobb Power Supplies 4 08-15-2006 08:20 PM
Electronics people, help me with a custom circuit Greenbuggy Hardware Development 3 03-07-2005 08:53 PM
Need help reading ring generator circuit Crashless Hardware Development 9 02-21-2005 06:19 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
