Old 11-18-2007, 09:28 PM   #1
Power Supply Question
Ive done a bit of a search but cant exactly find what i need.
Im running a laptop style dc converter into my little car PC, runs at 19V max 3.2amp.
Ive read not to run car PC's off the cig lighter, but this should be ok no? cig lighter is rated at either 15 or 20 amp, not sure, and the converter has a 10amp fuse as well.....
This would be my avenue for an ACC power supply. if i went a constant power supply im worried about the comp accidently staying on if i were to build a relay style control board- do the shutdown controllers do all that, like have a timer and detect if its on for too long when the car isnt... etc? So what inputs/outputs do u need for the startup shutdown controller?
For a constant supply, what size wire would be suitable for the 3 amp mark direct from the battery (fused of course).
thanks heaps
toymachine is offline   Reply With Quote
Where was that picture of the power supply out of car? Question about bench testing? forrestang General Hardware Discussion 2 01-30-2008 09:32 PM
FAQ: Power Supplies Explained (Part 1) Bugbyte The FAQ Emporium 14 06-10-2007 07:45 AM
Power supply Problem xGROMx Power Supplies 8 03-16-2007 01:19 PM
FS: ITPS shutdown controller and PW-70a MINI-ITX power supply hanzacra Classified Archive 4 08-07-2005 10:32 PM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 12:13 PM
