The MP3car.com Store
Thread Tools Display Modes
Old 11-26-2007, 06:50 PM   #1
Phatsacks's CarPC Specs
Phatsacks's Avatar
Vehicle: 2007 Corolla S
My Photos: (0)
PSU Selection Confirmation
I try not to post without searching, and I believe I figured the power consumption out:
I purchased an AMD X2 BE-2300 (45) processor.
I will be using two case fans, and a 3.5" hard drive.
From reading, all of these pull from the 12v line. USBs pull from the 5v.
So, rough calculations:
45w, 2x 5w, 20w (hard drive is the 20w, and from charts is rounded up)
So, I should need at least a 75w 12v line, and the M2-ATX provides 8a on the 12v line, which is 96w.
The 5v line will be supplying 5-6 USB devices, which is up to 30w total. The 5v line provides 8a, which should be 40w max.
So from these numbers, am I correct that the m2-atx should do just fine?
I was about to pull the trigger on the DSATX+brainstem which was $180.xx with shipping from mp3car, but if I can save $100 as it's "not needed", then that's the way to go.
Any confirmations are appreciated!
(by the way...I could be way off on everything!)
Edit:
I forgot about the monitor...
About 10w, and pulls off the 12v as well? If so, that would be pushing it a tad (if I'm even correct)
Phatsacks is offline   Reply With Quote
Sponsored Links
Old 11-27-2007, 04:49 PM   #2
Phatsacks's Avatar
My Photos: (0)
Screw it, got the DSATX+brainstem!
Hopefully it ships out soon like everything else I ordered from everywhere else!
Old 11-27-2007, 05:05 PM   #3
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Good choice.
Sponsored Links
vB code is On
Trackbacks are Off
Remove Case DC-DC PSU? Uther Power Supplies 1 08-27-2006 10:33 AM
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 06:25 PM
Mastero 3.5 12v-12v PSU KIT fs SteveC Classified Archive 0 09-28-2004 11:04 AM
Powering up normal ATX PSU KimaX Power Supplies 5 09-28-2004 12:08 AM
Morex 80w PSU not working????? NiN^_^NiN Power Supplies 2 09-04-2004 11:52 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
