The MP3car.com Store
Thread Tools Display Modes
Old 01-06-2008, 02:44 PM   #16
crooper's CarPC Specs
crooper's Avatar
My Photos: (0)
Quote: Originally Posted by Stang70Fastback View Post
2. I've decided to not use the third ignition cable for the PSU but instead installed a rocker switch on the positive power cable to the PSU. I haven't installed it yet, but will it be possible to have the PSU start up whenever it just gets a current? (AKA the rocker switch?) Should I just splice the 12 V positive cable and connect it to both the positive and ignition inputs on the PSU?
I wouldn't recommend putting a switch on your +12v power wire and splicing to +12v and rem. That kinda defeats the purpose of having a startup/shutdown controller. If you're worried about draining your battery from a PC that won't shut down, then just adjust the power kill jumper on the M2 to something that sounds reasonable. I have mine set to kill the power at 1 minute, because my PC always hibernates before then.
I think what you're trying to do here is what's called a "valet switch", where you have a manual switch on the ignition/acc/remote line so you can control whether the carpc (and/or amps) turns on or not. I've got one of these and it's great. Your remote line can be very small wire (like 18 or even 24 awg) because it only needs like 200 ma to tell the M2 to turn on. Wire it to the cigarette lighter to get ACC power.
crooper is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Should distribution block fuses be used?!? lexdiamond20 Newbie 24 05-24-2007 06:28 AM
Battery Wire Problem BrianL Car Audio 4 04-08-2007 07:12 PM
'97 5-spd Maxima, first carputer attempt... wasyed Worklogs 42 11-30-2006 03:41 PM
FAQ: How to Wire an OPUS PSU Quattro The FAQ Emporium 74 08-26-2006 12:38 PM
Pure oxygen free wire? Gearhead61 Car Audio 11 04-25-2006 01:49 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
