Old 01-08-2008, 06:38 PM   #1
Electrical People..! Farads and Power Ques...
Ok ive done a bit of a search but couldnt find what i want....
My comp runs a dc-dc converter. 19V max 3.5Amps.
My questions how long would a 1 farad capacitor run it for? im thinking sweet FA...but im not sure on the calcs...
If 1 farad = 1 colomb at 1 volt
and 1 colomb = 1 amp in 1 second
1 farad = 1 amp in 1 second at 1 volt? Im not sure
so pretty much no time at all....?
Cheers
toymachine is offline   Reply With Quote
Old 01-08-2008, 06:52 PM   #2
Ok after looking a bit more, the capacitor i think would discharge in about 5 seconds, but its not constant output, it declines... rapidly. so this would help for crank survival, but FA else
Old 01-08-2008, 06:53 PM   #3
you're going to need to know at what voltage the computer will turn itself off at. Then maybe doing it like a RC time constant problem.
Let's say it shuts off at 80% of full voltage, because it's drawing 3.5 amps (I just used what you supplied) 19/3.5 = 5.43 which we will use for R.
T=RC= amount of time it takes for voltage at the cap to decay to 63%.
so work it kind of like an exponential decay and you have your answer.
About 1.2 seconds at that current.
I cheated and used this calculator though. I'm pretty sure the percent is not a percent of voltage it's percent from voltage. So I used 20% for the example.
h3rk is offline   Reply With Quote
Old 01-08-2008, 07:10 PM   #4
Yeah thats how i looked at it too. cheers
