11-22-2008, 09:46 AM
#16
I'm using the Opus DCX6-320 and have been very satisfied with it. Just to give you a rundown on what it can power from my experience, read the list below:
I have it connected to an Shuttle FT20 motherboard with three thermaltake 80mm fans while running a 2.2Ghz dual core socket 939 processor, 2x2GB of system ram, a dedicated PCI-Express GPU card - the BFG Nvidia GeForce 8500GT 1GB DDR2, Sound Blaster X-Fi Professional series add-in sound card with 64MB of XRAM.
For the hard drives, I have two 3.5", WD150AFD 10,000 rpm Raptors in RAID0 (the pair have since been replaced by a 300GB, 10,000 RPM VelociRaptor, and a 7,200 RPM, 1.5 Terabyte Seagate Barracuda). Also connected to the power supply is a full sized 24X Samsung lightscribe multi-format dvd burner, a Dynex 30 in 1 multi-format USB memory card reader, three four-port USB hubs daisy chained, totaling twelve peripherals that are always on. Drive letters B, C, D, E, F, G, H, I, J, K, L, M, O, P, are in use by Windows Vista.
If you thought like I did, that the PSU was already at maximum overload, get this- the DCX6-320 is also providing a constant 12Volt regulated power output to my seventeen inch widescreen flat panel LCD display!
Rest assured, tried, tested, and approved...this is the only power supply you would realistically ever need for automotive purposes.
Bang for the buck, I'll admit the Opus DC6-320 is a tad bit on the high side, nevertheless, it has been in use for over a year now and has outperformed the actual PSU that came with the Shuttle ST20G5 gaming PC box, and also the Antec450 aftermarket PSU.
I ordered mine online, through www.opussolutions.com. The package arrived on time as promised, double boxed with popcorn foam. Included were the wiring harness (2 ea), external mount LED with connector, various jumpers, and installation instructions.
The DCX6-320 is assembled with superior craftsmanship using some of the finest electronic components. I give it a 10 out of 10 kick*** product rating
~DMand
11-22-2008, 09:58 AM
#17
And here I thought swapping out my single core 939 to a dual core might be 'iffy' for my 320!
Outstanding!
11-22-2008, 10:15 AM
#18
WuNgUn, I too was skeptical at first with my dual core, two raptors, and a 17"inch monitor. I kept adding more stuff while closely monitoring the outputs.
I've come to the conclusion that the DCX6-320 is a rock solid performer. A great buy, well worth every penny in gold.
02-04-2009, 02:06 PM
#19
Quote:
Two Remote trigger outputs of the DC-DC can be used to turn on/off slave devices such as head units, Audio Amplifiers, LCD monitors, DVD players, Two way radio units, etc. One regulated 12V output (3.5A max) available for powering peripheral devices such as LCD monitors, WiFi radios, etc.
This was on the details site for the OPUS 320W Intelligent DC-DC PSU. So i gather you can power a monitor with the PSU, if so, where is the connector for the monitor?
02-04-2009, 02:31 PM
#20
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
You can power it on various 12V connection. You can attach it to the orange accessory wire, or the Yellow wire on the Molex Connector. The orange and yellow both share the same power and can support up to 15 amps. With my huge set up that has also has two 100 watt inverters, VGA powered splitter, and 5 touch screens, I simply hooked all to direct power from the car, since they all have regulators, then connected them to a relay. The relay is then connected to the 12V line of the PSU. That way no strain is being put on the PSu at all....
HiJack ZX1 CFSC
CAR PC ITEMS [ 35%]
INSTALL OF MULTI PC SYSTEM [ 35%]
BUG WORKOUT [ 0%]
INTERIOR MODS [ 45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
03-29-2009, 11:05 AM
#21
Hey does anybody know of anywhere there has been testing done on this power supply (to see variation under load, power output on 12 vs 5v and 3.3v) im trying to figure out if this is a solution that will run a stable pc or if it will be the source of instability in a pc.
04-02-2009, 12:38 PM
#22
Can anybody do any testing with thier power supply to see if and under what type of load this power supply falls outside of the ATX DC voltage regulations listed on page 13 of the ATX 2.2 Standards? I would realy like to know how much these things variate and if they even come close to falling into the ATX standards. Most desktop power supplies fall short on the ATX standard due to DC voltage issues.
06-08-2009, 03:02 AM
#23
~DMand
This is almost the configuration that I want to run in my CarPC. I have a Shuttle BareBones XPC that I want to use, would this Power Supply work or does the MOBO have to support it, or would I have to go the Inverter route?
06-08-2009, 03:36 AM
#24
Nevermind, I found the answer to my question. Sorry to be such a Noob but there's a lot of stuff to read in these forums. Looks like the 360W OPUS is the newer version so I'll probably go with that. Thanks for the review!!
09-11-2009, 11:58 PM
#25
Quick question...The ground wires (3 of them), and the 12v to the battery (3 of them) , should those just be "tied" together?? And why was it done like that?
Why not just one for each? Example...one to the 12v one to the Battery ground, one to the ACC?
BossTone74
09-12-2009, 12:57 AM
#26
The OPUS 320, handles 320 Watts, so you have to use a heavy gauge wire. I think rather then using a heavy 8 gauge and lower, which may be hard to work with, they simply made them seperate. For me this idea worked. I split the end of my 8 gauge wire into 3 areas, tied the 3 OPUS wires onto the 8 gauge, then weaved them into one, then soldered them.
So basically it was done to make it easy to work with. So yes, use all three on each side. It could have also been for financial reasons. Its cheaper to have 3 smaller wires then one big one maybe? I think its my first conclusion though.
HiJack ZX1 CFSC
CAR PC ITEMS [ 35%]
BUG WORKOUT [ 0%]
HiJackZX1 Work Log
HiJackZX1 Website!
09-16-2009, 05:37 PM
#27
i have the opus 360 w....
i just received it..
but there is three input for the 12 volt et 3 for the ground??..i dont understand...
Carputer:
Psu: DCX6.360-H
Mobo: Intel D945GCLF2
Ssd: ssd ocz solid state 30gb
ram : 1024 meg kingston 667 mhz
Sound card : asus xonar d2 pci
Fan : one nexus and one noctua
case : i'm building a new one
09-16-2009, 06:00 PM
#28
could i plug just one of them?
Carputer:
Psu: DCX6.360-H
09-16-2009, 06:34 PM
#29
summer69guy, you know better. I answered this very question for someone else a few posts up.
POST:
The OPUS 320 (360), handles 320 (360) Watts, so you have to use a heavy gauge wire. I think rather then using a heavy 8 gauge and lower, which may be hard to work with, they simply made them seperate. For me this idea worked. I split the end of my 8 gauge wire into 3 areas, tied the 3 OPUS wires onto the 8 gauge, then weaved them into one, then soldered them.
So YES, use all the wires!
HiJack ZX1 CFSC
CAR PC ITEMS [ 35%]
BUG WORKOUT [ 0%]
HiJackZX1 Work Log
HiJackZX1 Website!
| Thread Tools |
| Display Modes |
Linear Mode
