Old 01-09-2008, 06:13 PM   #1
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
FAQ OPUS 320W Intelligent DC-DC PSU FAQ Thread
This thread will serve to post all relative information for the Opus 320 watt Intelligent DC-DC PSU.
This thread is not to be used for troubleshooting, but rather for FAQ type responses.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Advertisement Sponsored links
Old 01-11-2008, 01:57 PM   #2
msun is an unknown quantity at this point
For PC to work properly with remote power on and hibernate, the BIOS has to support ACPI 2.0 to work with Opus 320W.
msun is offline   Reply With Quote
Old 01-14-2008, 12:40 AM   #3
surfpangea is an unknown quantity at this point
The opus 320 does not fit in varoom case
surfpangea is offline   Reply With Quote
Old 01-14-2008, 01:46 AM   #4
tracker64 is on a distinguished road
it's just a circuit board, how can it NOT fit... anywhere?
tracker64 is offline   Reply With Quote
Old 01-23-2008, 12:27 AM   #5
TJ31324 is an unknown quantity at this point
Little love for the Opus 320. How bout someone with some knowledge and the PSU could explain what the 10 wires on the input harness are for?
TJ31324 is offline   Reply With Quote
Old 01-23-2008, 03:33 AM   #6
_
When in doubt, reading the product manual is always a safe bet: http://store.mp3car.com/ProductDetai...4&Show=ExtInfo
Accordingly, on page 3 of the manual
In order of the pins:
  1. GND
  2. GND
  3. GND
  4. ON/OFF
  5. 12V out
  6. +BATT
  7. +BATT
  8. +BATT
  9. RMT-1
  10. RMT-2
Jan Bennett
Old 01-23-2008, 09:13 AM   #7
Yea I printed out the whole manual but I wouldent mind a short explination of where the wires go?
Old 02-20-2008, 10:34 AM   #8
DeltaFX's Avatar
DeltaFX is on a distinguished road
hey, isn't there a dedicated place for Noobz, Newbies and beginners ?
Well uh, I don't want to look harsh, but if you can't figure how to connect these wires (with pretty explicit names), then you're slightly unprepared to mess with carputers
GND = Ground (negative pole of the battery which means the body of your car
+ BATT = positive pole of the battery
On/Off = probably is to be connect to a switch with other wire connected to ground
12vout = stabilized 12v output
RMT1/2 = remote 1/2 to be connected to amp and other systems
Pfff damn noobz
Now Galileo is real. Muhahahahaha :p
DeltaFX is offline   Reply With Quote
Old 02-20-2008, 12:42 PM   #9
Just dont wanna fry anything I knew where everything went except the 12v wire didnt notice it was output. Thanks
Old 02-23-2008, 06:21 AM   #10
morganspydergt is an unknown quantity at this point
n00b
im an electrical engineer n i had a miss understanding there myself too , you just wanted to burn on an upid question , but n another note that rmt=remote , tanks , that cleared my question , n made up my mind , this is not the one i need cause im not opening the dash in my new truck.....
morganspydergt is offline   Reply With Quote
Old 04-11-2008, 02:52 PM   #11
Mod - Driveline forum
ClockWorK's Avatar
ClockWorK is on a distinguished road
Mounting
The screw-holes on the Opus 320 circuit board are too small to accomodate 6-32 machine screws. 4-40 works though.
ClockWorK is offline   Reply With Quote
Old 04-30-2008, 05:30 PM   #12
dasaint80 is on a distinguished road
I'm having an issue that the remote cables are not turning my amps on.....anyone have that problem..... am I missing jumpers or something like that?
dasaint80 is offline   Reply With Quote
Old 09-24-2008, 09:57 AM   #13
WuNgUn's Avatar
WuNgUn is on a distinguished road
Haven't installed PSU yet, but my manual says my mainboard has ACPI & PC2001 enhanced power management...
What about 'standby'? Do you need the 2.0 standard for that as well?
WuNgUn is offline   Reply With Quote
Old 09-24-2008, 05:27 PM   #14
Not sure but I'd assume no, since standby is drawing almost same current as ON?
Old 09-25-2008, 12:06 AM   #15
WuNgUn's Avatar
I think your thinking of WinXP standby, where the PC just goes into a fully-on slumber....lol
Vista 'sleep' is completely powered down, except the memory (and probably USB devices) remain powered up...
MUCH less current drawn than 'on'...
ITX PSU - What Alternitives Are There To The Opus One ccsnet Power Supplies 8 05-28-2003 07:41 AM
What to look for in a PSU some info for you cproaudio Power Supplies 9 04-04-2003 02:07 AM
Opus DC - DC souljetta Power Supplies 14 03-21-2003 02:07 PM
wtb: harddrive, dc dc psu and slim slot dvd kardas Classified Archive 3 05-21-2002 06:11 AM
Must have for those using Aztec Laptop DC PSU DodgeMp3Enabled Classified Archive 0 03-02-2001 10:18 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
