The MP3car.com Store
Thread Tools Display Modes
Old 01-09-2008, 05:17 PM   #1
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
FAQ DSATX 220 watt Automotive Power Supply and Brain Stem
This thread will serve to post all relative information for the DSATX 220 watt Automotive Power Supply and the Brainstem.
This thread is not to be used for troubleshooting, but rather for FAQ type responses.
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Sponsored Links
Old 01-11-2008, 07:40 AM   #2
Lazyflip's CarPC Specs
Lazyflip's Avatar
Vehicle: 2002 VW Jetta 1.8T
My Photos: (12)
Brainstem Guidelines
Quote: Originally Posted by zootjeff View Post
1. Don't Hot-Plug the brainstem! Hot plugging it causes it to hiccup the micro controller and causes weird results.
2. If you do Hot-Plug it and you want it to behave normal, do the following:
Take a Jumper and short pins JP1 A2 and B2. Be very careful when you do this. (Don't randomly short out everything with tweezers.) Shorting A2 to B2 will put the DSATX in the Reset state and reset any weirdness you created from hot-plugging your brainstem. You must then un-short it for it to come out of the reset state.
3. You must enable writing if you are going to change parameters
The when you want to set paramters you must (E)nable writing first. A capital E will then ask you if you want the DSATX to burn the EEPROM with new settings as you type. Yes. Then you won't get line feeds for every key as your typing an S command.
4. F and O will turn on and off the Feed Diagnostic Output. If you type, you should see an echo. That means you have hyperterminal setup right.. It you type and you don't see anything, your not setup right. 9600 baud, 8 bits,1 stop bit, no parity, no flow control.
5. The brainstem is plugged in right if it goes into the 4 pin connector without trouble. The circuit board of the brainstem should not hit the white housing of the connector.
FYI:
Hot-Plug means connecting the brainstem connector to the DSATX while there is 12V on VIN. When ACC is has 0V and VIN has 12V, that IS a Hot-Plug. You can also use use needle nose and pull the fuse (Or disconnect VIN from the battery) rather than shorting the pins to correct the problem.
You can disconnect the VIN from the battery (for 5 or more seconds) and it will have the same effect as the reset.
Here is a youtube:
http://www.youtube.com/v/y9cSO2sNrxk
02' JETTA 1.8T | WORKLOG ALBUM
Lazyflip is offline   Reply With Quote
Old 02-24-2008, 10:25 PM   #3
Ineffigy's CarPC Specs
Vehicle: 2005 Toyota Celica GTS 6
My Photos: (0)
If you have a motherboard that expects the -5 volt signal instead of the +5 volt signal, and you build the reverse polarity circuit (cable) as shown here , you may end up with the power supply starting and then stopping a few seconds later. This is caused by the cable you created was plugged in incorrectly. The single wire goes to the MB power On pin which is the pin that is closer to the center of the board. The other cable then plugs into your motherboard.
Ineffigy is offline   Reply With Quote
Old 02-24-2008, 10:34 PM   #4
WiCKeD 5.9L's CarPC Specs
Vehicle: 1998 Jeep Grand Cherokee 5.9L
My Photos: (0)
Ineffigy, glad it worked for you. I tried every combination x 10 and it kept having the boot issue.
Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D T7200 / MB: MSI Fuzzy 945GM2 / SC: E-MU 1212M SC / RAM: Corsair 512MB / HD: Hitachi 7K200 2.5" 100GB / DVD: Panasonic UJ-815B / PSU: Opus 150w / LCD: 7" Xenarc
WiCKeD 5.9L is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
FS: DSATX 220 Watt Power Supply Norrin302 Classified Archive 5 06-13-2006 07:36 AM
FS: M1-ATX 90 Watt - Smart Automotive Power Supply csnv Classified Archive 1 09-30-2005 12:46 PM
New Mpegbox Power Supply zootjeff Power Supplies 60 09-20-2005 12:32 PM
FS: OPUS 150 watt DC-DC power Supply wh0k Classified Archive 17 03-25-2005 04:56 PM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 09:29 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
