I bought a refurbished DSATX from you guys. I didn't expect to need to build the cables, but apparently you can't get them. The local PC shop, was kind enough to give (gasp - give!) me two burned out ac-power supplies from which I could salvage all the connectors and cables to make my own.
If you are going to build your own cable, it pays to keep a clear head. There are a lot of wires - easy to get confused. I used crimp connectors and heat-shrink tubing.
I installed the DSATX on standoffs in the box of one of the dead ac power supplies the pc dealer gave me. I removed the fan from the box, becaue my 3u case has 3 fans. box is installed in front of case and fans draw all air for system through DSATX power supply box, then over drives and MB, then out the back.
IT WORKS GREAT. I'm using a bit more than 1/2 the amps the inverter and old ac ps used. Typically 65 watts/ compared to 120-130. On our boat,this is critical because old setup was second biggest battery sucker after refrigerator. We have eight 6 volt golf cart batteries wired for 12 volts and we have to run genset to recharge them.
Intel D945gcpe w/2 gig RAM
Core Duo 2.2 E4500
2 3.5 hdd,s one SATA, one ultra ata plus usual 3.5 floppy
Audigy 2 platinum w/front panel
ATI All-in Wonder Radeon 7500 (this is our TV)
LiteOn DVD drive.
I used the jumper to thwart the board's many options and it turns on and off just like a conventional PC -
what a great product.
