Old 03-31-2008, 12:28 PM   #16
supramad77 is an unknown quantity at this point
anyway to use the m2-atx on a pc with no where to conect to. I have a car pc that won't work well otherwise.
supramad77 is offline   Reply With Quote
Old 03-31-2008, 12:34 PM   #17
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
what do you mean? can you be a bit more descriptive?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 03-31-2008, 12:43 PM   #18
There are no connections for the main plug to fit into. Not sure if there is a way around this or if i have to buy a diffrent pc.
Old 04-03-2008, 03:30 PM   #19
BlazingBird's Avatar
BlazingBird is an unknown quantity at this point
M2-atx
How much power will be consumed in an 12 and half hour period. Will this thing drain my battery while in hibernation? I know it has the shutdown protection but is that enough?
BlazingBird is offline   Reply With Quote
Old 04-03-2008, 03:52 PM   #20
_
that depends on your computer, not the power supply, as it's the computer that determines power consumption, not the power supply.
Jan Bennett
Old 04-30-2008, 05:34 PM   #21
dasaint80 is on a distinguished road
Hey all, I'm having an issue that the remote Jumper (JU6) not turning my amps on...
dasaint80 is offline   Reply With Quote
Old 05-13-2008, 10:02 PM   #22
mrroboto560 is an unknown quantity at this point
where do you connect the ignition cable? (the white one) for the m2-atx-hv
mrroboto560 is offline   Reply With Quote
Old 05-14-2008, 09:22 AM   #23
To the ACC from the Key Ignition.
Old 05-15-2008, 12:00 AM   #24
ok that answers my frist question, heres my new second one. when i turn on my car, the hdd starts the spin up, fans turn on, but it only gets half way through the post and stops, but when i hit the reset, it boots perfect.
any suggestions?
Old 05-15-2008, 12:02 AM   #25
WuNgUn's Avatar
WuNgUn is on a distinguished road
any suggestions?
Corrupt hibernation files?
Are you sure your not using 'sleep' instead of hibernation?
XP is notoriously bad with hibernation...
Vista hibernation (when activated) works flawlessly on my rig....
WuNgUn is offline   Reply With Quote
Old 05-15-2008, 11:55 PM   #26
i am actually having this problem too.
how can i fix the files
yes hibernation, unless the GUI is lying to me... :-P
which version of XP would be good with hibernation? i have XP home on my laptop and it works great.
baa vista....
Old 06-02-2008, 11:47 AM   #27
Ricksastar's Avatar
Ricksastar is an unknown quantity at this point
whats the difference between the -hv and the other?
Ricksastar is offline   Reply With Quote
Old 06-02-2008, 11:53 AM   #28
_
high voltage input enabled.
Jan Bennett
Old 06-02-2008, 11:54 AM   #29
Ricksastar's Avatar
so is that a better thing to have or does it not matter?
Old 06-17-2008, 09:57 PM   #30
SSteveSC is an unknown quantity at this point
what are all the wires for on the harness??
SSteveSC is offline   Reply With Quote
Where can I buy an ATX DC to DC PSU online? Ritalin Kid Classified Archive 8 07-19-2002 12:04 PM
250 Watt ATX DC-DC PSU mhermann Power Supplies 9 01-28-2002 03:34 PM
dc dc psu for a micro atx case y0manda Power Supplies 0 12-23-2001 07:04 PM
85 dollar DC to DC ATX PSU citrus3000psi Power Supplies 4 07-21-2001 07:56 PM
Has anyone tried modifying a 110v atx PSU to 12v DC? HappyPuppy General Hardware Discussion 15 11-12-2000 11:03 AM
