Old 07-06-2009, 04:37 PM   #61
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Quote: Originally Posted by peterfnet View Post
anyone have issues with this with RFI?
Trying HD Radio and computer is causing a lot of RFI and destroys the FM signal. I'll be trying an AC PSU to see if there is a difference.
absolutely does KILL the reception in my car. Also effects my alarm when the computer is powered. I wish there was somethin that could be done about it.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 07-06-2009, 04:45 PM   #62
peterfnet is an unknown quantity at this point
Thanks for chiming in so quickly. Glad to hear i'm not the only one. Anyone upgrade to a different model and not have this problem? I'll report back when I try a different PSU.
peterfnet is offline   Reply With Quote
Old 07-06-2009, 04:48 PM   #63
I'm reading this right now. Very similar issues.
http://www.mp3car.com/vbulletin/powe...erferance.html
Old 07-06-2009, 05:10 PM   #64
rickd is an unknown quantity at this point
Hmmm. I used this power supply for a 12-volt computer to use as a logging computer for amateur radio field operations at about 14 MHz. I do not hear any RFI from the computer or power supply, when running from 12 volts. Our systems are quite sensitive to this, with sensitivity running down to -130dBm.
When I use this computer in my motorhome, I do not hear it at all on an FM ham radio running at 147 MHz, whose antenna is only a couple of feet from the computer. I do get quite a lot of ignition noise in that radio, however, which I need to correct. The broadcast FM band is between those two frequencies where I have used this computer.
I have more problems with lines running across my cheapie touch screen, which gets its power from the 12-volt bus on this power supply. But I think that's the monitor. I only see it when it's being used in the motorhome, and I think the power line to the monitor is coupling with ignition wires (which are very close by)--that's probably the same thing causing the ignition noise in my 2-meter ham radio.
I have not put a scope on the output, but it seems reasonably clean.
Rick "who would eliminate other possibilities first" Denney
rickd is offline   Reply With Quote
Old 07-06-2009, 05:17 PM   #65
Interesting. I know I'm guilty of RF and power wires running next to eachother.
I also am an amateur radio operator. I experience RF interference really only when the HDD is chugging on resuming from hibernation.
Lots of things to try... :-)
Old 07-07-2009, 09:34 AM   #66
joshuo is an unknown quantity at this point
What if you shielded the PS?
Maybe the wires too?
*edit*
Like with this stuff:
ArgenMesh Shielding Fabric
joshuo is offline   Reply With Quote
Old 07-07-2009, 10:15 AM   #67
Terminal flasher
*edit*
never heard of the stuff personally. Would that be conductive material?
03 Acura RSX Coupe
Old 07-07-2009, 10:32 AM   #68
Yea, it's fairly conductive (< .5 Ohms According to the manufacturer, Similar to Germanium)
I'd put electrical tape on the inside of the cloth, then wrap the PS (maybe the whole computer box.
on a side note, People with tons of RFI, do you use a premade metal case? that might shield the RFI, being metal and all...
Old 07-07-2009, 11:48 AM   #69
*edit*
Shielding the power supply should help a bit, but I would not use soft conductive materials. If the soft stuff sags into the circuit board, you'll get fireworks. You'd be better off making a box out of lightweight sheet metal. Even very heavy gauge aluminum foil (the "heavy duty" stuff) should be able to hold its shape well enough to prevent shorting out. I would not wrap the PS in an insulator--that will eliminate air circulation and there must be some heat loss from the voltage regulators. I would mount a cover such that it provided openings all around it.
As I said before, I do not get RFI from the computer. But I did use an all-metal enclosure that is grounded.
There is a significant possibility that the RFI is coming from the motherboard or hard disk and not from the power supply. To really know for sure, you would need to unplug everything from the PS and then power it up. Ideally, you'd put a purely resistive dummy load on the power supply outputs, but that will require some careful knowledge. At five volts, a 5-ohm resistor will pull one amp, and a 20-ohm resistor will pull 250 milliamps. At 12 volts, a 10-ohm resistor will pull 1.2 amps. These need to be 20-watt resistors--wire-wound resistors in ceramic will do fine. They are cheap at Radio Shack.
Given the data transients on the motherboard, I've never figured out how they can avoid RFI, and I suspect that a metal enclosure is absolutely required for them to get FCC approval.
For shielding the power lines to the monitor, which I suspect is the reason I'm seeing interference patterns there, I recommend a shielded power cable. I haven't done that but I will. Snap-together ferrite beads (also a Radio Shack item) on the power cable and on the VGA cable might work just as well. My cable snake to the monitor runs parallel to the main wire coming from the alternator on the engine of my motorhome, and the significant RFI I'm hearing from the engine in my 2-meter ham radio is suggesting that the engine compartment is putting out some serious RF.
RickD.
Old 07-07-2009, 12:06 PM   #70
The engine def. puts out tons of RFI, that's another reason why firewalls in cars are metal.
Just think of the amount of metal that spins at 1000's of RPMs and all the metal on metal rubbing... Add a turbo and it gets even worse.
another thought on shielding:
It could be as simple as covering the computer box with some sheet aluminum or even metallic paint?
Old 07-07-2009, 12:20 PM   #71
Terminal flasher
I'm using an aluminum case professionally made and it has made a difference but the interference is still there. Its definitely from the power supply too, if i switch PSU's to a house PSU it goes away.
03 Acura RSX Coupe
Old 07-07-2009, 12:20 PM   #72
how about aluminum tape?
Old 07-07-2009, 12:22 PM   #73
Terminal flasher
when you say your case is grounded what specifically do you mean. You've run a wire from your case to the same ground as your power supply? I've tried this but it made no difference in any of my 6 carputer setups. This RFI issue is really the LAST issue i have before i have a perfect CarPC in my mind
03 Acura RSX Coupe
Old 07-07-2009, 12:25 PM   #74
Have you tried grounding the case, PSU, MB, TS, and the Radio to the same ground?
Old 07-07-2009, 04:24 PM   #75
Grounding a big issue, and cars these days have a careful grounding plan. Ground loops can play hell with sensors for engine management computers.
Grounding for RFI is different, though. Effectively grounding for RFI requires a very low impedance ground path. Running a little wire from the case to the body may not be good enough. My case is grounded to the main ground point on the vehicle through 10-gauge wire, which is still marginal from an RFI point of view. But it's the best I can do. For ham radio equipment in my home, I use copper flashing as a ground conductor.
More importantly is the ground on the receive antenna for the radio receiving the RFI from the computer. The shield and the ground plane of the antenna should be grounded very carefully with a very low impedance ground conductor. A 10-gauge wire to the negative lead on the battery sounds about right. That will help shunt to ground any coupled signals reaching the shield on the radio antenna.
RickD.
Where can I buy an ATX DC to DC PSU online? Ritalin Kid Classified Archive 8 07-19-2002 12:04 PM
250 Watt ATX DC-DC PSU mhermann Power Supplies 9 01-28-2002 03:34 PM
dc dc psu for a micro atx case y0manda Power Supplies 0 12-23-2001 07:04 PM
85 dollar DC to DC ATX PSU citrus3000psi Power Supplies 4 07-21-2001 07:56 PM
Has anyone tried modifying a 110v atx PSU to 12v DC? HappyPuppy General Hardware Discussion 15 11-12-2000 11:03 AM
