Old 07-11-2009, 02:08 PM   #91
joshuo is an unknown quantity at this point
Are there any PSU's that have a better track record with RFI?
I heard they pretty much all suck...
joshuo is offline   Reply With Quote
Old 07-13-2009, 09:09 AM   #92
peterfnet is an unknown quantity at this point
Well, I was the one that brought up this RFI business. turns out the PSU is likely not the cause of my RFI.
I pulled my vehicle into the garage and plugged in an AC power supply to the wall and the interference still existed.
I get AM and AM HD great though!
FM still sucks. Considering I'm running an older motherboard with a P4, perhaps a newer generation of technology will help.
The current case is steel. http://www.newegg.com/Product/Produc...82E16811154062
There is a vent in the top. Maybe that's letting the RFI 'bleed' through.
This is in an Explorer. Computer is in the back. The radio is under the back seat.
@joshuo. I heard that some people like the OPUS better. I was going to go down that road until I had the same results with an AC PSU.
peterfnet is offline   Reply With Quote
Old 07-13-2009, 11:55 AM   #93
I don't think it would. It should still act like a cage of Faraday. S mesh is fine as long as it is grounded as well. (unless it has a rubber gasket sealing it from the box, i don't see why it would give you issues.
Old 07-26-2009, 01:50 AM   #94
alpax is an unknown quantity at this point
Quote: Originally Posted by Virac View Post
Im having a few problems with my M2-ATX.
1. When i turn off my car the power pulses and the computer does a hard restart, then 5 secs later will shut down, I have the jumper in position 1. I have tried swapping the IGN and POW lines but I know that is not the issues cause when i turn off the car the computer powers off instantly and when it comes back on i get a warning that the system didn't shutdown properly.
I'm having the same issue - when I turn the ignition off, there seems to be some kind of a power pulse, the computer simply powers off without proper shutdown, though the monitor stays on (or maybe it just turns back on right away). In 5 seconds everything turns off.
Update: Finnally got a 13.8V AC/DC power supply and the M2 behaves properly. For other reason main power must be fluctuating.
So it wasn't enough voltage? Could it be the case for me too?
D945GCLF2, Atom 330, M2-ATX, EBY-701, Pharos GPS-500... - Assembled & Installed!
alpax is offline   Reply With Quote
Old 08-25-2009, 12:33 AM   #95
Just wanted to share my experience. I had this problem, tried to replace the PSU - no change, the new one behaved the same way. I did some more experiments and finally could make it work as it should!
I just used the power filter, which came with Lilliput: connected the ignition through that filter, and it solved the problem! Now it works as it should.
Old 08-25-2009, 01:42 AM   #96
trader007 can only hope to improve
yes, i can also confirm that if your batt+ is hooked to a power source that fluctuates when you turn the REM lead off- the m2 will shut off completely for a split second and then resume normal shutdown pulse.
its not really a fault with the m2 though. you must have the batt+ of the m2 powered with a steady 12v at least even when shutting the ignition off (this fluctuation can happen on more circuits then you would think) so if its happening its really an install problem.
ludikris, im guessing that power filter has capacitors in it, thats why its working for you. im sure any decent sized cap across the batt+ and batt- of the m2 would help in those situations.
trader007 is offline   Reply With Quote
Old 08-25-2009, 02:41 AM   #97
Hmm... I thought the whole idea of this PSU was to receive unregulated input, which could fluctuate from 6 to 24V, and output steady 12V, 5V, and 3.3V.
If it cannot handle this, I believe it's definitely a design flaw.
BTW, in my case the power from the battery+ is pretty steady - I double-checked that.
Old 08-25-2009, 01:21 PM   #98
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
It does not need to be regulated 12v, it can be anything. It can survive down to 6 or 7 I think when cranking. It works just fine on mine.
I think what he is saying (although I have never experienced this to be true) is anything between 12v and charging voltage is ok when shutting down, lower and it doesnt?
On mine though I can do whatever and it works. I can turn on the HID lighting which draws an ENORMOUS current from the battery fast with the car off and the CarPC in its 30s before shutoff, and the PC will keep on truckin'. I can start the car when the CarPC is in its 30s before shutoff which definately dips it to 6 or 7 and it will keep working just fine.
Only difference is I have the regular M2, not the M2-HV. Also I have a real M2. If you bought it off of ebay for $30 to $50 then you have a chinese knockoff copy that has known problems. Lots of problems. You get what you pay for. Expect $70 to $90 new.
Old 08-25-2009, 01:48 PM   #99
Yes - that's how it's supposed to be. In my case any disconnection of the ignition line - when I was turning the key to OFF or starting the engine - caused some impulse from the PSU, which instantly powered off my computer without shutting the OS down, and eventually it died so could not boot up. My fix with adding a filter on the ignition line made it work as it should. Now I can start the engine with the computer running, can turn the ignition off, then back on - it's working. Only after 5s delay (I use P1 mode) it starts shutting down.
Mine is the regular M2 as well, and it seems to be real - I bought it for ~$75 from mo-co-so.com.
Old 10-19-2009, 11:18 AM   #100
Skipjacks's Avatar
Skipjacks is on a distinguished road
Skipjacks is offline   Reply With Quote
Old 10-20-2009, 03:26 PM   #101
benjadeed is an unknown quantity at this point
Reset of power supply
Hi,
whenever the engine cranks the M2-ATX resets(i.e. the power is gone for about a second and its back) hence the car pc boots again after the crank of the engine. is there any way to not make the power supply reset itself while cranking??? or will a 12v regulator to the power supply help????
benjadeed is offline   Reply With Quote
Old 10-21-2009, 05:24 PM   #102
Just read several posts above - I had the same problem. In my case it seemed to be the ignition.
M2-ATX design is really not that good.
Old 10-21-2009, 08:32 PM   #103
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
I'm having this same exact issue. M2 works fine in bench but when I put it in car it cuts power hard when the ignition turns off..
I have the M2's constant connected directly to the battery, the switched connected directly to an ignition wire at the ignition harness, and the ground to ground..
It powers up correctly (5 seconds after IGN wire is powered).. It gets into Windows fine and runs fine.. However, the second I turn the vehicle off power is instantly cut and the computer shuts off..
I metered my constant during the whole process and it never dips under 12V (unless my meter isn't fast enough to catch it)..
So WTF could be wrong?
I have the jumper on B but it does the same thing on A as well..
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 10-21-2009, 09:43 PM   #104
Yep, everything exactly like mine. I also metered the voltage - it was fine.
My guess is that M2-ATX controller doesn't like the shape of the ignition signal when the ignition turns off/on, goes crazy and cuts the power for a moment.
I could be wrong - just guessing, but I solved the problem by adding a filter to the ignition line.
Old 10-21-2009, 10:25 PM   #105
Raw Wave
tbird2340's Avatar
Doesn't like the "shape"? What does that mean?
I don't get it.. If the hot line is getting a constant 12V then how can it totally cut power when the IGN line loses power?
And it doesn't power back on after that like some have said.. It totally cuts power.
Where can I buy an ATX DC to DC PSU online? Ritalin Kid Classified Archive 8 07-19-2002 12:04 PM
250 Watt ATX DC-DC PSU mhermann Power Supplies 9 01-28-2002 03:34 PM
dc dc psu for a micro atx case y0manda Power Supplies 0 12-23-2001 07:04 PM
85 dollar DC to DC ATX PSU citrus3000psi Power Supplies 4 07-21-2001 07:56 PM
Has anyone tried modifying a 110v atx PSU to 12v DC? HappyPuppy General Hardware Discussion 15 11-12-2000 11:03 AM
