03-31-2008, 11:28 AM
#16
anyway to use the m2-atx on a pc with no where to conect to. I have a car pc that won't work well otherwise.
03-31-2008, 11:34 AM
#17
_
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
what do you mean? can you be a bit more descriptive?
03-31-2008, 11:43 AM
#18
There are no connections for the main plug to fit into. Not sure if there is a way around this or if i have to buy a diffrent pc.
04-03-2008, 02:30 PM
#19
M2-atx
How much power will be consumed in an 12 and half hour period. Will this thing drain my battery while in hibernation? I know it has the shutdown protection but is that enough?
04-03-2008, 02:52 PM
#20
_
that depends on your computer, not the power supply, as it's the computer that determines power consumption, not the power supply.
04-30-2008, 04:34 PM
#21
Vehicle: 2008/Scion/Xb
Hey all, I'm having an issue that the remote Jumper (JU6) not turning my amps on...
05-13-2008, 09:02 PM
#22
where do you connect the ignition cable? (the white one) for the m2-atx-hv
05-14-2008, 08:22 AM
#23
To the ACC from the Key Ignition.
05-14-2008, 11:00 PM
#24
ok that answers my frist question, heres my new second one. when i turn on my car, the hdd starts the spin up, fans turn on, but it only gets half way through the post and stops, but when i hit the reset, it boots perfect.
any suggestions?
05-14-2008, 11:02 PM
#25
any suggestions?
Corrupt hibernation files?
Are you sure your not using 'sleep' instead of hibernation?
XP is notoriously bad with hibernation...
Vista hibernation (when activated) works flawlessly on my rig....
05-15-2008, 10:55 PM
#26
i am actually having this problem too.
how can i fix the files
yes hibernation, unless the GUI is lying to me... :-P
which version of XP would be good with hibernation? i have XP home on my laptop and it works great.
baa vista....
06-02-2008, 10:47 AM
#27
Vehicle: 2006 Ford Explorer
whats the difference between the -hv and the other?
06-02-2008, 10:53 AM
#28
_
high voltage input enabled.
06-02-2008, 10:54 AM
#29
so is that a better thing to have or does it not matter?
06-17-2008, 08:57 PM
#30
what are all the wires for on the harness??
| Thread Tools |
| Display Modes |
Linear Mode
