Old 01-09-2008, 06:19 PM   #1
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
FAQ M2-ATX(-HV) 160 watt Intelligent DC-DC PSU
This thread will serve to post all relative information for the M2-ATX 160 watt Intelligent DC-DC PSU or the M2-ATX-HV 160 watt Intelligent DC-DC PSU.
This thread is not to be used for troubleshooting, but rather for FAQ type responses.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Advertisement Sponsored links
Old 01-15-2008, 01:40 PM   #2
cobase is an unknown quantity at this point
I think we can include here that the J8 pins HAVE A POLARITY. Plugging the connector in backwards (50% chance!) can cause the M2-ATX to malfunction and be damaged! The board's manual says to check the polarity of the connections carefully, but many of us didn't think a simple switch had a polarity! (We're wrong because it's not a simple switch). Seems this has caused at least half a dozen board failures already, most recently summarized here:
http://www.mp3car.com/vbulletin/powe...-problems.html
Elantra GT 1.2GHz Duron, RoadRunner & LSX Void 3.2. Status: Stable...
cobase is offline   Reply With Quote
Old 01-15-2008, 05:45 PM   #3
nobb will become famous soon enoughnobb will become famous soon enough
Are you sure that is correct? It doesnt say anything in the manual that J8 has polarity.
"The M2-ATX board has several wires that need to be installed in various places.
When installing, always double check the polarity of your wires with a voltmeter."
I always though that statement applied to things such as power or ignition wires. I blindly connected my power supply without regards to polarity and everything has been working for a few days. Which way is it +/- on the M2-ATX? On the EPIA M10000 mainboard, it actually gives the polarity of the power switch.
nobb is offline   Reply With Quote
Old 01-15-2008, 05:54 PM   #4
galvitron's Avatar
galvitron is an unknown quantity at this point
Which pin is which on J8?
Someone should link to that resistor swap that that guy did (can't find the thread right now)
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 90%
Installation/Fab/Assembly (Revised v2):
[----------] 90%
galvitron is offline   Reply With Quote
Old 01-16-2008, 11:59 AM   #5
I just compared the specifications listed on the manuals for the M2-ATX and M1-ATX. Perhaps your theory on the polarization of J8 only applies to the M1-ATX? If you look on the specs table for the M1-ATX, the very last row says that J2, J4, J8, J6 are "Polarized Headers." However, on the specs table for the M2-ATX, this row has been removed. Maybe they redesigned the on/off header switch for the M2-ATX?
Old 01-16-2008, 12:18 PM   #6
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
i dunno if this is true or not but it would completely explain why my last one died when connected correctly.
and for my FAQ contribution here is the timing chart listing all available times (more than the listed times in the instructions)
http://www.mp3car.com/vbulletin/atta...mperchart2.pdf
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 02-03-2008, 04:21 PM   #7
WuNgUn's Avatar
WuNgUn is on a distinguished road
Why was I told (in another thread) that these power supplies came with the 4-pin, square mainboard aux. power plug? (See image)
Product info says nothing of this....
Can it be spliced in? Anyone know the pin-outs? Is there a female plug onboard that supports this plug layout?
And what is the difference between the two M2's, the base and the HV model? Can't find any documentation on that either!
WuNgUn is offline   Reply With Quote
Old 02-03-2008, 05:17 PM   #8
Mine didnt come with the 4 pin plug..I think it is an addon that you buy separate. You can slice into it if you need +12 for some reason. Yellow is +12v, black is ground. You can just make the part yourself if you have the connector head.
I dont know why the HV version is cheaper than the normal version. The only difference seems to be that the HV accepts up to 32v input, whereas the normal version accepts 24.
Old 02-04-2008, 12:19 PM   #9
galvitron's Avatar
My M2-ATX does indeed have that 4pin P4 style connector in addition to the normal ATX 20pin.
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
Old 02-04-2008, 03:13 PM   #10
Raw Wave
kickercivic1's Avatar
kickercivic1 is on a distinguished road
Can someone confirm this?
kickercivic1 is offline   Reply With Quote
Old 02-07-2008, 09:59 PM   #11
Nermin's Avatar
Nermin is an unknown quantity at this point
"board failures" what?!?!?!? and I'm about to connect mine to the "real world"
Nermin is offline   Reply With Quote
Old 02-15-2008, 03:17 PM   #12
japeeler's Avatar
japeeler is an unknown quantity at this point
No Problems whatsoever with mine in the real world hookup!
Also, I have the 4Pin 12V+ header on mine for the P4/PCI-X Power connections.
I am fixint to hook up my Lilliput to the P/S, as well.
The Polarity issues are "NOT AN ISSUE" as they have been re-programmed/fixed to compensate for plugging the mobo/case switch in backwards, it just functions like the power switch on the PC usually did, " Did not work"
japeeler is offline   Reply With Quote
Old 03-04-2008, 01:39 PM   #13
cMags's Avatar
cMags is on a distinguished road
"Hidden" Shutdown Controller (SDC) Operation Modes
Found out from the lead engineer at mini-box.com that there are more SDC jumper settings than are listed in the manual. Here's the full list:
ABCD OFFDELAY / HARDOFF
0000 standard PSU
1000 5 seconds / 1 minute
0100 5 seconds / 2 hours
1100 5 seconds / never
0010 30 seconds / 2 hours
1010 30 seconds / never
0110 30 minutes / never
1110 3 hours / never
0001 10 minutes / 1 hour
1001 15 minutes / 2 hours
0101 1 hour / 1 hour 15 minutes
1101 5 seconds / 2 hours (SureStop)
Enjoy!
CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
cMags is offline   Reply With Quote
Old 03-16-2008, 11:14 AM   #14
jimp is an unknown quantity at this point
So given this, then I hope I am posting this question to the proper thread as I feel this is a "FAQ type item"
Is the IGN feed wire (the center yellow wire of the main 3 inputs) simply a discreet 12 volt sense input to the boards logic or is there actually a substantial current flow on this wire? I am asking for obvious reasons like can I get by with using an 18 gauge wire as opposed to that huge wire that comes in the kit and also so I know I can connect it to any source without worry of overloading a circuit?
sorry to ask what should be a needless question but I find very little useful info on this PSU, it comes with absolutely no documentation, and the online manual is sparse at best.
jimp is offline   Reply With Quote
Old 03-21-2008, 06:44 AM   #15
ludikris is on a distinguished road
Just tried it tonight... looks like the M2-Atx can also run the rogers portable internet modem off the 12V rail.. I just cut into the floppy line and wired up the modem and voila..
Shame my motherboard isn't compatible.. :-(.. just draining off the 5V rail....won't boot often...
ludikris is offline   Reply With Quote
Where can I buy an ATX DC to DC PSU online? Ritalin Kid Classified Archive 8 07-19-2002 12:04 PM
250 Watt ATX DC-DC PSU mhermann Power Supplies 9 01-28-2002 03:34 PM
dc dc psu for a micro atx case y0manda Power Supplies 0 12-23-2001 07:04 PM
85 dollar DC to DC ATX PSU citrus3000psi Power Supplies 4 07-21-2001 07:56 PM
Has anyone tried modifying a 110v atx PSU to 12v DC? HappyPuppy General Hardware Discussion 15 11-12-2000 11:03 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
