Old 06-19-2008, 04:50 AM   #31
Bunter2000 is an unknown quantity at this point
Alternative
I bought a PC 12V power supply from a local supplier in Brisbane, Australia (Jaycar) it is nothing fancy but for under $100 and 250Watts it works well. I have opted to have more control over the PC by selecting when I want to use the PC with the M3 it is really designed to auto start even if you do not want the PC on.
I have an E34 BMW and am happy with the original head unit so I chose to use am FM transmitter as my interface to the radio. It may not sound as good as direct connected but for my personal use it good enough for me. I have a switch on the dash that connects through a 12Volt ignition supply and another momentary switch to start the PC.
I port the audio to the touch screen speakers and the FM transmitter so if I just want to listen to the radio but require the GPS I can select a local station on the radio and turn up the monitor volume to hear navigation info.
I can turn off the PC manually or via a timer (also jaycar), when I turn off the car the timer kicks in and holds the 12V supply on for an additional 15 seconds and at the same time a relay momentary pulses the pc switch line which starts the hibernate process.
The standby current when all is off including the timer is 300 microamps so the drain on the battery is far less than the security flashing LED in the radio.
Bunter2000 is offline   Reply With Quote
Old 07-14-2008, 11:23 AM   #32
fallingbear is an unknown quantity at this point
jaycar power supply
hey bunter,
could you please tell me what that power supply was called from jaycar??
i tried looking it up, and could not find it on their website?
thanks
fbear
fallingbear is offline   Reply With Quote
Old 07-15-2008, 07:36 AM   #33
Thumbs up
Quote: Originally Posted by fallingbear View Post
hey bunter,
thanks
fbear
II miss quoted , its 205 Watts not 250 anyway its a Powertech 205W DC-DC ATX power supply, on the bottom of the box is a part number ?? XC-4876.
I know you can find it on the jaycar website.
Hope this helps
Old 07-15-2008, 09:39 AM   #34
thanks bunter,
i rang them today, found it thanks,
how have you found the unit??
for $99 cant complain, but would be good if it is a good unit as well?
cheers
fbear
Old 07-16-2008, 02:45 AM   #35
Falling Bear,
So far I have not had a problem with it. The only thing I dont like about it is that it does not regulate the 12 Volt line. I was testing my PC on the bench using a 6 Amp battery charger and decided to monitor the 12 volt rail and the 12 volt rail fluctuated from 11.5 to 13.4 volts under varying changes in load caused by the PC.
When I checked the bios it also reflected similar changes in voltage, but I had no problems at all with the operation and left it going continuously for 24 hours and had no sign of any problems.
As it is just a power supply and you want auto cut off with ignition you will need a couple of relays and a timer to hold the 12v battey onto the power supply until the PC hibernates.
I can hand draw my setup for you if you want
Hope this helps
Old 08-06-2008, 01:17 AM   #36
Jistari's Avatar
Jistari is an unknown quantity at this point
Oddly enough, I switched from the Jetway MB that was giving me problems to an MSI (fuzzy GM1) and my M3 atx is working perfect now. Just thought Id update since I posted that I had problems with it here.
PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
Jistari is offline   Reply With Quote
Old 08-06-2008, 04:41 AM   #37
thanks bunter!!
sounds all a bit too much hoo har for me though, i am thinking of just keeping my laptop for now, and then when the ssd computers come on line, will then update??
seems it wont be too long till an ssd com is here, with everything in it, the size of a cig box?? self powered with its own solar panel on top??
will just need a screen then?
even then, the small hand held projectors might do the job??
future looks bright
cheers
fallingbear
Old 11-06-2008, 07:32 AM   #38
coreyspeed is on a distinguished road
i am think of getting one of these power supplys and would like to now if it has a fuse and if it is 1u complaint, i.e fits in a server case.
coreyspeed is offline   Reply With Quote
Old 11-06-2008, 04:03 PM   #39
power supply
Coreyspeed
The power supply will need mount points that are non standard however it is possible (never tried) it may replace the board in a standard 200W power supply box that is found in most ipx and low profile mini atx cases.
The board is L120 x W60 x H22 has a 4 pin DIN socket at one end for 12Volts in and a standard 20 Pin ATX power connector the other end.
I hope this helps
cheers
Bill
Old 04-16-2009, 05:55 AM   #40
tobmag is an unknown quantity at this point
Ive been running my car PC with the M3-ATX for some weeks now and I know that my car battery isnt the best. Overnight it will drop below 11,2volts and the M3 will shut down completely. However when startning the car it will not switch on again when the engine is running......I have luckely a switch that I can manually switch the computer on-off in the front of the car and by doing that the PC starts up again. Shouldnt the M3 do this automaticly when the voltage is ok again?
BR//Tobmag
tobmag is offline   Reply With Quote
Old 04-16-2009, 06:18 AM   #41
RevheadKev is an unknown quantity at this point
What mode are you running your PSU in ?
If you have it in mode P0 then it behaves like a normal ATX PSU and will not send a signal to the motherboard to turn on.
RevheadKev is offline   Reply With Quote
Old 04-17-2009, 03:15 AM   #42
Hi.
No Im running in P1 that is recomended, Its working Ok when Ive been running the car for a while and makes a short stop, its starts up as it should but when the voltage is below 11,2 and I start the engine it will not go on when the voltage rises.
BR//Tobmag
Old 05-13-2009, 03:39 PM   #43
DrLove is an unknown quantity at this point
Timings
Hi, I have the M3-ATX and I don't like the way the PSU shut down timings work. If U read the Timing settings documentation U can find this two contradicting explanations of the shut down sequence:
Quote:
(Page 2)
P1: Sends ON pulse to motherboard when ignition is ON for more than 2 seconds, sends OFF pulse to motherboard 5 seconds after ignition is turned off. Waits another 1 minute and then shuts down 5VSB to conserve battery.
Quote:
(Page 4 regarding P1)
In this mode M3-ATX sends ON pulse to motherboard when ignition is ON
for more than 2 seconds. After ignition is turned off first time since the PSU running the PSU waits 1 minute in case of the user changes his mind and turns back ON the ignition. If the ignition remains turned off in this extra 1 minute timeout the PSU sends OFF pulse to motherboard after 5 seconds later. As a result in P1 mode the PSU begins to turning off the motherboard after a total time of ~1 minute and 5 seconds.
My M3-ATX uses the second method and I want it to function like the first. I have used the software to reprogram the modes to no avail.
How does your PSU work regarding shutdown?
DrLove is offline   Reply With Quote
Old 05-13-2009, 07:51 PM   #44
Vicinity is an unknown quantity at this point
Does anyone know how I can get a replacement jumper for the M3? I lost mine.
Vicinity is offline   Reply With Quote
Old 07-21-2009, 02:52 PM   #45
Balk is an unknown quantity at this point
I'm planning on an all in-dash cpu install so I'm looking at pico-itx sized main boards. Does anyone have a setup they recommend with this PSU (M3-ATX)?
Balk is offline   Reply With Quote
NIB M2-ATX DC-DC ATX auto car PC power supply mini ITX EPIA ichiban Classified Archive 6 07-21-2006 01:00 PM
What size inverter for 200w PC power supply? plus ATX shutdown question JiminyC Newbie 8 08-23-2005 12:43 AM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 01:13 PM
Very Small/Mini Power ATX Power Supply? xBrady Power Supplies 10 06-20-2004 07:22 PM
More info on OPUS automotive ATX power supply InvisiBill Power Supplies 3 08-16-2002 03:19 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
