Old 01-09-2008, 06:25 PM   #1
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
FAQ M1-ATX 90 watt Smart Automotive Power Supply
This thread will serve to post all relative information for the M1-ATX 90 watt Smart Automotive Power Supply.
This thread is not to be used for troubleshooting, but rather for FAQ type responses.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Advertisement Sponsored links
Old 10-10-2008, 03:01 PM   #2
hastingr is an unknown quantity at this point
Will the M1-ATX run the Intel D945GCLF2 Board?
It appears that the Motherboard may have an extra connector.
Thanks in advance!
hastingr is offline   Reply With Quote
Old 01-22-2009, 12:48 PM   #3
RESET's Avatar
RESET is an unknown quantity at this point
Can I take power from the 12V rail of this power supply to connect to the P4-12V connector on my new motherboard? I don't want to get a new PSU just for the extra connector.
I guess I should ask. Will 90 Watts be enough to power a D201GLY2A mother board and a SATA hard drive? If it isn't big enough I guess I will just have to get an M2-ATX.
RESET is offline   Reply With Quote
Old 10-05-2009, 05:42 PM   #4
Biggles's Avatar
Biggles is an unknown quantity at this point
I have an issue with my M1-ATX just like the one that has been reported for M2-ATX as well:
I want my PC to hibernate on Acc loss but whenever I cut Acc power to the M1-ATX using the ignition key the PC does a hard reset, starts to reboot and finally gets killed by the M1-ATX hard power-off timer. The odd thing is that it only happens if I use the key. If I leave the key in Acc position and instead manually disconnect the Acc wire to the PSU the PC hibernates just fine.
I discussed this with an electronics engineer and we came to the conclusion that this probably happens because the acc bus in the car might be briefly connected to ground when turning the key. I would need something faster than a multimeter to find out.
Anyhow: I put a rectifier diode (100V, 3A) inline with the Acc input to the PSU and the problems are gone.
/Erik
Biggles is offline   Reply With Quote
New PicoPSU-60 (6-26vdc input) ik632 Power Supplies 1 10-03-2006 12:18 PM
What size inverter for 200w PC power supply? plus ATX shutdown question JiminyC Newbie 8 08-23-2005 12:43 AM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 01:13 PM
Very Small/Mini Power ATX Power Supply? xBrady Power Supplies 10 06-20-2004 07:22 PM
ATX, ITX DC-DC Power Supply Navigator_82 Power Supplies 4 03-14-2004 11:26 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
