Old 01-09-2008, 06:31 PM   #1
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
FAQ Carnetix CNX-P2140 185 watt Dual Output Regulator
This thread will serve to post all relative information for the Carnetix CNX-P2140 185 watt Dual Output Regulator.
This thread is not to be used for troubleshooting, but rather for FAQ type responses.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Advertisement Sponsored links
Old 01-15-2008, 01:07 PM   #2
StreetDeckAce is an unknown quantity at this point
Customer Question: I work in the robotics lab here at Stanford and have been using a few of your P1900 units on some of our robots to power PC''s from car batteries. They have worked flawlessly for over a year, so I''d like to
stick with your products.
I am building up a new robot that runs off a giant lithium battery pack. The pack discharges down to about 22 volts, and when sitting on the charger, the supply floats up to 36 volts. I would like to run a Mac Mini using one of your P2140 units. However, I saw that the upper voltage rating is 34 volts. Is there some margin in that rating, or is it a hard limit?
Answer: I would definitely drop the voltage. If you run the P2140 in over-voltage conditions (more than 26V) for longer than a short moment will probably case the P2140 to cut power to prevent any damage or fires.
StreetDeckAce is offline   Reply With Quote
Old 04-19-2008, 12:36 AM   #3
rgarjr's Avatar
rgarjr is an unknown quantity at this point
Typical diagram of the 2140..
My carpc worklog
rgarjr is offline   Reply With Quote
Old 08-05-2008, 06:21 PM   #4
rgarjr's Avatar
Typical diagram showing how to use a standard automotive relay to feed all of your computer devices requiring 12V battery, 12V ignition, and ground.
My carpc worklog
Old 09-16-2008, 01:44 PM   #5
insaneramman's Avatar
insaneramman is an unknown quantity at this point
Question Dell SX280?
Is anyone using this unit to power a SX280 PSU says 12v @ 18 amps. I am quite sure (plz don't suggest a search been done) it doesn't draw that much. I would like to know if anyone has used this psu for this comp. Just FYI comp specs are - 2.8ghz, 1gb, SATA HD. Any help would and will be appreciated.
insaneramman is offline   Reply With Quote
Old 06-15-2009, 03:10 AM   #6
Carz is an unknown quantity at this point
Since Infill G4 already has it's own psu, would CNX-P2140 still works for my Infill G4 to power 1 if not 2 x 4-port usb hubs (read it's better if usb syncronised) and wireless 3g router (12v?)? If it does but is overkill, I would not mind since I could reuse it if I ever switch to standalone car pc.
Sorry, I've no background in electrical engineering and so would like minimum wiring solution though I've access to someone who can help me with the wiring if needed.
Carz is offline   Reply With Quote
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
CarNetix CNX-P5V Point Of Load Regulator Now Shipping MikeH Power Supplies 17 06-10-2008 05:41 AM
Newbie Carnetix p2140 - SX260 Question dw_uk2000 Power Supplies 3 08-15-2007 12:28 PM
WTB: CarNetix CNX-P1290 Dual Output 90 Watt 12V DC-DC Regulator HACKTHS Classified Archive 0 01-15-2006 09:45 PM
Carnetix CNX-P1260 60 Watt DC-DC Regulator parawing742 Classified Archive 3 01-26-2005 03:54 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
