Old 01-09-2008, 06:33 PM   #1
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
FAQ Carnetix CNX-P1900 Dual Output 140 watt Regulator
This thread will serve to post all relative information for the Carnetix CNX-P1900 Dual Output 140 watt Regulator.
This thread is not to be used for troubleshooting, but rather for FAQ type responses.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Advertisement Sponsored links
Old 01-20-2008, 10:04 PM   #2
Firebird2 is an unknown quantity at this point
Earthing Case
Hi guys,
One quick tip with regard to the P1900.
Do not earth the case. This will cause issues with Suspend/Hibernation of systems.
For example, if you screw the case to any part on the car that is earthed it does not work correctly.
Firebird2 is offline   Reply With Quote
Old 01-22-2008, 06:00 PM   #3
JDizzle's Avatar
JDizzle is an unknown quantity at this point
Even if I screw it into plastic?
JDizzle is offline   Reply With Quote
Old 01-22-2008, 06:07 PM   #4
_
it's not going to ground if it's plastic....
Jan Bennett
Old 03-20-2008, 05:09 PM   #5
RobPfis07 is an unknown quantity at this point
so wait should i not ground it at all? because im having a problem with my P1900 and macpac. it puts my mac mini to sleep beautifully when i turn off the ignition, but after about 2 or 3 minutes the P1900 shuts off, cutting power to my mac. but itll start the mac up again on ignition and works fine. the only thing it wont do is let my mac sleep in piece. it keeps cutting the power. thanks.
EDIT: whoops sorry i had a jumper set wrong. i thought i had them all right. sorry.
RobPfis07 is offline   Reply With Quote
Old 05-19-2008, 08:33 PM   #6
Rocket976 is an unknown quantity at this point
I have my unit attached to plastic, however it is grounded through the wiring is this a problem as I am experiencing shut down a few minutes after sleep?
Rocket976 is offline   Reply With Quote
Old 05-19-2008, 10:49 PM   #7
rgarjr's Avatar
rgarjr is an unknown quantity at this point
If you are grounding the black wires off the power connector to chassis ground, then that's the correct way of doing it.
My carpc worklog
rgarjr is offline   Reply With Quote
Old 04-13-2009, 02:07 PM   #8
bluenoserforeve is an unknown quantity at this point
Dell 9
They mention this works with the Mac Mini but why not laptops in general? I've ordered a Dell Mini for my car and it has an input of 19V at about 65W I believe so is there any reason this power supply wouldn't work with my laptop?
Need an adapter of course but assume that's implied.
bluenoserforeve is offline   Reply With Quote
Old 04-14-2009, 08:51 PM   #9
Re: Laptop
I can't see why it wouldnt work I will try my macbook on there for you and let you know. Never thought about doing that... Give me a few hrs, or pm me back if I forget to come back on.
Old 06-26-2009, 07:55 AM   #10
hpgia is an unknown quantity at this point
hey guys,
I'm having some problems with the hibernation of my mac mini. i've used the ignition from the radio for P1900. I used it all the time without the radio being attached and it worked fine.
Now that I've mounted the radio, the computer won't sleep. only when i pull the power cable from the radio, it goes into stand by.
do u have any idea why this is happening?
hpgia is offline   Reply With Quote
Old 09-17-2009, 10:33 AM   #11
n2k
n2k's Avatar
n2k is on a distinguished road
I have an old CNX-1900 140W Dual Power I bought back in 2005 so It's probably version 1.0
And now I have a fit-pc2 computer that accepts input of 8-15V and a 7" LCD that wants 12V.
is possible to power these two with the CNX-1900 ?
n2k is offline   Reply With Quote
CarNetix CNX-P5V Point Of Load Regulator Now Shipping MikeH Power Supplies 17 06-10-2008 05:41 AM
19 volts? Conan257 Power Supplies 6 10-06-2005 05:00 AM
Carnetix P1900 issues MobiTekLink Power Supplies 4 08-05-2005 06:38 PM
Carnetix CNX-P1260 60 Watt DC-DC Regulator parawing742 Classified Archive 3 01-26-2005 03:54 PM
140 watt inverter btomasie General Hardware Discussion 1 05-19-2000 12:16 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
