The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 01-10-2008, 06:46 PM   #1
jumbodogs's CarPC Specs
jumbodogs's Avatar
Vehicle: 97 Dodge Ram
My Photos: (12)
Speakers Pop when computer shuts down
I am getting this popping sound from speakers when I shut down the computer in my truck. I am using the rem wire on my M2-ATX to power my amps on.
jumbodogs is offline   Reply With Quote
Sponsored Links
Old 01-10-2008, 07:57 PM   #2
jontz's CarPC Specs
jontz's Avatar
Vehicle: 2001 Ford F-150 Ext. Cab
My Photos: (0)
I'd power your amp turn on lead with something other than your opus, something that turns on with the accessory position on your ignition. When you turn the key off, your amp will turn off instantly, while your mobo will take a few seconds to power down, eliminating your turn off thump.
jontz is offline   Reply With Quote
Old 01-10-2008, 10:46 PM   #3
jumbodogs's Avatar
My Photos: (12)
I thought M2-ATX was suppose to take care of that thump.
Old 01-11-2008, 01:44 AM   #4
My Photos: (0)
Did you ground the other pin?
tacobandit is offline   Reply With Quote
Old 01-11-2008, 08:53 AM   #5
jumbodogs's Avatar
My Photos: (12)
No I did not .... should I?
Old 01-11-2008, 08:59 AM   #6
danielkh's CarPC Specs
danielkh's Avatar
Vehicle: 2004 Nissan 350Z
My Photos: (0)
Follow this thread. It works flawlessly for me. The M2-ATX never worked right for me.
http://www.mp3car.com/vbulletin/car-...-carputer.html
danielkh is offline   Reply With Quote
Old 01-11-2008, 05:02 PM   #7
jumbodogs's Avatar
My Photos: (12)
Hey thanks I am gona give that a shot.
Old 01-11-2008, 05:48 PM   #8
My Photos: (0)
Okay i guess i am confused on what they actually did, do they still use the m2 to turn on the amps? Or from the computer?
Old 01-11-2008, 06:52 PM   #9
danielkh's Avatar
My Photos: (0)
They are using a program in windows to turn the amps on and off by using the serial port. You do not use the m2 at all for amps.
Old 01-11-2008, 07:30 PM   #10
My Photos: (0)
Okay so how do you wire up the amp to do that?
Sponsored Links
Old 01-11-2008, 07:53 PM   #11
danielkh's Avatar
My Photos: (0)
There is a lot of info on this in the forum, but in a nutshell....
1. Download the amp control program.
2. Find an old serial cable and cut it open.
3. With the program, turn on and off the "amp" (in the program)
4. Find which wire is putting out 12V when turned on (think this is called the dtr pin)
5. Run that wire directly to the "amp on" of the amps
6. Setup .bat files as I describe in the other thread
Done!
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Hardware Review: Mobile Computing Solutions Mini ITX 2ghz Computer (and peripherals) danielkh The Review Palace 34 05-27-2008 08:19 AM
The legalities of wardriving. PURDooM Wireless Communications 200 01-29-2008 05:26 PM
Computer shuts down randomly Gewehrschuss Power Supplies 1 06-23-2004 03:38 AM
Sponsored Links
Ad Management by RedTyger
