Old 01-20-2008, 05:44 AM   #1
pnyboy27 is an unknown quantity at this point
carpc not turning on with power supply
i have an aopen pc with a carnetix p1900 v2.2 power supply. im pretty sure i have all the connections correct, but for some reason, it doesnt turn on the pc. heres what i have connected:
input side:
i have one red wire connected to the battery with 15amp fuse; one black wire connected to a ground source; yellow connected to the ignition wire; blue, red, black covered with electrical tape
output side(i got the aopen power pack from the site):
one red to pc; one black to pc; one black to acpi(pc)/screen; brown to screen; green to acpi(pc); blue to amp remote; white, and red covered with electrical tape
when i connected it, and turn on the car, the p1900 led lights up twice, then once, then 7 times, then no light. it only happens when i turn it on, or just plug it in. then it remains off. i try to turn on the pc by pressing the power button, but it doesnt turn on still. is there something i didnt do or did wrong?
pnyboy27 is offline   Reply With Quote
Old 01-20-2008, 05:45 AM   #2
oh, and just in case, heres my comp specs:
AOpen MiniPC i945GMx-F
Intel Celeron M 440 (Yonah) FSB533 1.86GHz
Old 01-20-2008, 05:44 PM   #3
i tested my battery and it tested out good at 12.77 volts..im still confused
Old 01-21-2008, 02:45 AM   #4
okay..update..so i guess i had the connections wrong..and heres a wiring diagram i found for my pc.
http://www.carnetix.com/p1900/Applic...pplication.htm
so then i rewired it:
input:
2 reds to battery via 15 amp fuse; 2 blacks to ground; yellow to ignition wire(ignition wire from stock harness to stock headunit), blue taped up and closed
output:
red/black to comp; brown/black to screen; red/green/white taped up and closed; green/black adapter to jp3 slot on power supply p1900 to computer acpi; blue wire to amp remote
so i still have the problem which it doesnt light up..and according to the troubleshoot on the installation manual..it says to check the battery..because if its less than 10.6volts then it wont start or light up..but my battery tested at 12.66volts with a full charge, 45% state of health...could it be my ignition switch? is the switch i have no small? when i checked with a multimeter, it showed around 12volts coming out of it too. im so lost and confused! i just need this to turn on then my project is basically done! HELP PLEASE!!
Old 01-21-2008, 02:49 AM   #5
oh..and i found out what those flashing lights meant..its the version of firmware i have which would be 2.7
Old 01-21-2008, 03:38 AM   #6
pokki is an unknown quantity at this point
Have you tried wiring the yellow acc to the + batt as a quick test of the PSU.
pokki is offline   Reply With Quote
Old 01-21-2008, 03:58 AM   #7
no..not yet. would that be something? ill try that tomorrow...so do you think it could just be the ignition wire?
Old 01-21-2008, 02:54 PM   #8
You thought it might be, so that's one way to test around it.
I'd also measure the voltage at the powersupply (with psu on) rather than at the battery as this will give you a good indication if you have voltage loss over your cables. In which case it's time to recheck your power cables, grounds and fuses.
Old 01-21-2008, 04:44 PM   #9
okay..i just tried jumping the ignition wire to the hot, and removed the acpi..still didnt work. i just tested the input of the psu, and it read a nice 12.6 volts..then i tested the output of the psu..and it read a 0.12 volts..that isnt right is it? so does that mean i have a bad psu?
Old 01-21-2008, 06:30 PM   #10
Ignore
Old 01-21-2008, 07:06 PM   #11
ignore? ignore what? i cant even turn on the comp by pressing the power button on the comp itself. im frustrated at the fact that this is my only problem..what could be wrong?
Old 01-21-2008, 07:42 PM   #12
krnpimpsta's Avatar
krnpimpsta is an unknown quantity at this point
When I had that problem it was because of a bad ground.
It was *A* ground, as in, I measured about 13.5V from + to -. But when any significant amount of current passed through it, the voltage drop increased (V=I*R.. R was high, so any I made V high).
It could be that your connections to ground or power are not ideal. How is your ground wire connected to the chassis? And how is your power wire connected? Crimps? Solder? Also, what gauge wire?
krnpimpsta is offline   Reply With Quote
Old 01-21-2008, 07:43 PM   #13
krnpimpsta's Avatar
Also, are you testing this with your car running? Your battery is only at 12.6V when the car is running? You may have a bad battery or alternator that's lost 1 out of its 3 coils - and about to fail.. you should typically get about 13.5-13.8V at the battery with the engine running, if your battery and alternator are healthy.
Old 01-22-2008, 03:56 PM   #14
okay, so i retested the wires, and with the car running, i am getting a nice 14.59V..and ill take a picture of my ground. its connected to the chassis via a bolt. my power wires are connected via butt connector crimps using 12 gauge wire.
Old 01-22-2008, 04:03 PM   #15
krnpimpsta's Avatar
Can you try unplugging the power wiring harness from your power supply - and then measuring the voltages at all the output holes? As in, verify that each one of the connectors that are supposed to be reading 14V are reading 14V - and that all the ones that are supopsed to be reading ground are indeed ground when compared to the chassis?
How can I use a laptop as a carpc? turbocad6 Laptops, Netbooks, Tablets, UMPCs, etc. 0 07-11-2007 01:55 AM
power supply confusion CapnBoost Power Supplies 3 04-26-2007 08:59 AM
Finalizing Power Supply Options Nstyle Power Supplies 2 04-01-2007 04:40 PM
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
power inverter power supply shutdown problem launter Power Supplies 10 09-21-2005 12:12 PM
