The MP3car.com Store
Thread Tools Display Modes
Old 01-21-2008, 10:00 PM   #1
My Photos: (0)
15 or 20 Amp Fuse?
I was told on here to use a 15 Amp fuse next to the battery in-line with my M3-ATX PSU, since that's what it's rated at, but I recently brought the car to a local audio place to have the guy there quickly redo a bit of the wiring with some switches and he said it'd be better to use a 20 Amp fuse since over the length of the wire it's going to lose a bit of voltage and draw a bit more amperage? This sounds reasonable, but I'm curious as to what you guys think?
Stang70Fastback is offline   Reply With Quote
Sponsored Links
Old 01-21-2008, 10:11 PM   #2
h3rk's CarPC Specs
Vehicle: 2006 Nissan Altima
My Photos: (0)
As long as that fuse is still rated less than what the wire from the Battery to the M3-ATX can safely handle (based on its gauge), then you should be fine. That fuse is there to prevent that wire from overheating and causing damage to it's environment (your car). *But current at one end of a wire can't be more than at the other, unless there are other nodes on it going elsewhere.
*Courtesy of: Kirchoff's Current Law.
h3rk is offline   Reply With Quote
Old 01-21-2008, 11:18 PM   #3
It ain't easy being a green moderator
meddler's CarPC Specs
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
Vehicle: 2001 Nissan 200sx
My Photos: (2)
Have a look here. About a 1/3 of the page down is a bit on wire sizes and max current draw. There is also a current calculator that calculates voltage drop across the length of the wire.
The last thing you want is for the wire to melt and short out. If you are not sure, always use a smaller fuse than you think. Worst case is the fuse blows.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
AMP Popping, Hissing, Shutting off...PLZ help?! Dougw133 Car Audio 8 12-10-2007 08:24 AM
On a 2 channel amp that I plan on bridging, do I need BOTH rca ins? FyreDaug Car Audio 67 10-15-2006 08:35 PM
Lost cylinder fuse in my LCD monitor. What amp replacement? PapaPrem LCD/Display 3 08-13-2006 01:13 PM
Amp Shuts Off ElementXofXMusi Car Audio 29 07-18-2006 07:34 PM
What AMP fuse to use? phatchink Newbie 17 01-18-2005 03:11 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
