The MP3car.com Store
Thread Tools Display Modes
Old 01-24-2008, 07:45 AM   #1
cMags's CarPC Specs
cMags's Avatar
Vehicle: '05 Subaru Impreza Outback Sport
My Photos: (0)
Difficulty w/ Built-in SDC on OPUS 150W / Book PC
My buddy is using an old P3 600MHz Book PC (info here: http://groups.msn.com/BOOKPC) with an OPUS 150W DC-DC. We've hooked up the SDC lines to the pwr_on header on the motherboard, and wired in a remote push-button in parallel for testing on the bench w/ a normal ATX.
The button works so we assume the signal from the OPUS will work too. The issue is, that the button will obviously start the PC, and a 4-sec hold will power it off, but pressing it once will not initiate a shutdown in XP (SP2). We've got ACPI enabled in BIOS, APM enabled in XP (which allows the PC to power off after shutdown instead of prompting us to), but we're still missing the "When I press the power button on my computer" menu.
Does anyone know what needs to be enabled in XP or BIOS to provide that menu so we can choose "Shutdown" or "Hibernate"?
Thx.
CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
cMags is offline   Reply With Quote
Sponsored Links
Old 01-24-2008, 10:17 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Did you have to turn on ACPI settings in the BIOS after Windoze was installed? If so, did you reinstall Windoze after you enabled it?
As far as I know, there's no way to simply install ACPI functionality after Windoze is installed. If there is a way to do so, I don't know what it is.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 01-24-2008, 12:58 PM   #3
cMags's CarPC Specs
cMags's Avatar
My Photos: (0)
Oh, good point. We did install XP first, then enabled ACPI. I'll have him re-install. He's getting a new drive anyway so he can re-install then. We were going to just partition image it to save on installing drivers, codecs, and worse: iGuidance, but o-well.
If anyone does know how to install the ACPP drivers in XP after enabling in BIOS, let me know soon!
Thanks!
Sponsored Links
vB code is On
Trackbacks are Off
FS: OPUS Mini-ITX Vehicle PC Case w/ built in 120w power supply / DVD+RW Drive jlucio Classified Archive 0 02-02-2007 05:32 PM
Custom mount for my OPUS 150W in ATX case Sham-Mobile Power Supplies 2 10-10-2005 10:00 PM
opus on but not pc fuctup Power Supplies 71 06-23-2005 03:13 AM
YAOP (yet another Opus problem) Frankino Power Supplies 14 06-19-2005 11:17 AM
Opus 150W, No Amp Control? mattwz Power Supplies 3 06-11-2005 10:42 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
