The MP3car.com Store
Thread Tools Display Modes
Old 02-04-2008, 10:30 AM   #1
My Photos: (0)
Which wire first?
Before I hook up my M3-ATX, I remember someone on this forum saying something about hooking up a certain wire first or you could fry it. I should assume ground. Which order should I go? I've got 12V from the battery, a ground and a fake "ignition" wire which is just basically another 12V battery source with a switch in line. All this with a 20Amp fuse.
Stang70Fastback is offline   Reply With Quote
Sponsored Links
Old 02-04-2008, 09:26 PM   #2
redls1bird's CarPC Specs
redls1bird's Avatar
My Photos: (0)
You should wire up your positive wire first. That way, if you make a mistake and touch something that you shouldnt, you wont have a ground to fry anything. When your attaching the ground wire afterwards, if you make a mistake and touch something you shouldnt, you wont hurt anything because the ground wire carries very little current. Also, you should connect these things with the ground cable on your battery disconnected just to be on the safe side.
Car Pc progress meter:
[-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
"The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
My worklog
redls1bird is offline   Reply With Quote
Old 02-05-2008, 01:17 AM   #3
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
Quote: Originally Posted by redls1bird View Post
...the ground wire carries very little current.
The ground wire carries the same current as the positive wire.
Personally I'd hook the wires up in the order : ground, positive, ignition.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
How to: Build a heater strip to bend acrylic for 30 bucks or less! greatwhite Fabrication 9 06-08-2008 10:53 AM
Question for Zootjeff, What's the DSATX white wire for? greatwhite Power Supplies 2 10-21-2007 12:18 PM
Question about wire to connect to battery thanassius Power Supplies 7 08-07-2006 10:35 AM
Totally dissapointed with my carputer! Maheriano General MP3Car Discussion 113 07-16-2006 08:26 PM
Pseudo-FAQ: What Do I Need For A Carputer? Maheriano General MP3Car Discussion 18 07-03-2006 02:04 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
