Notices
Old 02-19-2008, 04:45 AM   #1
shreyasma's Avatar
Help on DC-DC PSU for my CarPC with D201GLY2A
Hi Friends,
I am planning to implement my CarPC.
But i am a little stuck at choosing the right Power Supply Unit.
My Plan:
Intel D201GLY2A
Panasonic UJ-85J-B Slim Slot load DVD±R/±RW/+RDL/RAM Multi Drive
512MB DDR2 SODIMM PC2-4200 RAM
Xenarc 705TSV 7" TFT LCD Touchscreen Monitor w/ VGA & AV inputs
Major Brand 80GB 2.5" IDE Hard Drive
New Griffin Powermate Volume Knob
Mini-Key USB Keyboard DGPN-570
Bluetooth USB Dongle
Now which PSU can i choose from MP3car.com store??
I will be building the In-dash case on my own using help from u guys
Also help me to understand how to calculate the Power supply
Cheers to mp3car.com
shreyasma is offline   Reply With Quote
Old 02-19-2008, 10:35 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
I suggest reading the FAQs: http://www.mp3car.com/vbulletin/advfaq.php
All the information you need is in there.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 02-19-2008, 10:45 AM   #3
seninha's Avatar
Since this afternoon I am using a M2-ATX together with the same board you have.
It powers up the next items:
board
7" touchscreen
HQCT USB radio
USB hub
3 fans
1024 memory
120 gb notebook SATA hard drive
Am planning to also attache my 2 headrest monitors to the supply. I think it will hold whitout any problem.
Gods right foot!!
Mercedes ML320. Intel D945GCLF2,1024mb DDRII,160Gb S-ATA HD,HDradio,7"Touchscreen,2x 7"build in headrest screens,OBDII reader,Centrafuse.
seninha is offline   Reply With Quote
Old 02-20-2008, 02:36 PM   #4
-zip-'s Avatar
Opus 150 here (check my sig for components)
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 02-20-2008, 09:55 PM   #5
shreyasma's Avatar
thank you
hi friends,
thanks for your replies.
You guys rock!!!
Old 02-21-2008, 03:32 PM   #6
Woofnstuff's Avatar
i would go for 1gb of memory btw, its dirt cheap, and means you can allocate a bit more to the video memory.
and i didnt think these boards took SO-DIMM (laptop) memory should just be normal DDR2
i currently have a morex 80W car psu in mine, it survives crank well,
the screen and head deck are powered direct off the cars 12V not the cleaned 12v from the psu, since they are both designed to be in cars they can cope with the variance in voltages
i got one of these cases which fit under my front seat nicely (i got my local supplier to swap the 60W psu that comes with it for the 80W car one - $30nz extra)
http://store.mp3car.com/Morex_3677_M..._p/enc-022.htm
Edit:
additionally im looking at putting a small 12V 7Ah tank battery in as well, with a relay so when i turn the car off the computer can still shut down run whatever without impacting the cars battery
Woofnstuff is offline   Reply With Quote
Old 02-21-2008, 04:21 PM   #7
Self proclaimed spoon feeder
TruckinMP3's Avatar
I am using a PC power and cooling 90 watt dc to dc with my D201GLY2 it also powers my monitor, keypad and mouse.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
DC PSU for sale - Keypower 250W mosseri Classified Archive 1 09-08-2006 04:16 PM
Powering your CarPC out of the car the cheap way with ATX PSU lloydy Newbie 0 12-08-2005 11:41 PM
M1-ATX PSU DC 90watt - Ebay fr1daygta Classified Archive 0 11-16-2005 07:11 AM
Need help finding post: AC PSU into DC PSU skidogg77 Power Supplies 2 09-03-2004 12:28 PM
sproggy 2.7 dc PSU output? Help qdrw82 Power Supplies 0 11-05-2003 12:32 PM
