The MP3car.com Store
Thread Tools Display Modes
Old 02-19-2008, 06:59 AM   #1
seninha's Avatar
Vehicle: Mercedes ML 320 , 1999
My Photos: (0)
M2-ATX wont power Amp on
I just upgraded my system, and one of the things thats new is my power supply.
I had a M1-ATX and have now a M2-ATX.
Just installed everything in the car , all working fine except that the powersupply doesnt power up my Amplifier.
Because of this I messure the power coming out of the connector and this is 11.2V.
If I connect the cable to the Amp it drops to 8V
What can I do tho make the Amp go on. I bought the M2-ATX in the startes and I dont like the idea to send it back because if this.
Therefore I want to find a different solution for this problem. (maybe getting 12V form other part of the powersupply
Gods right foot!!
Mercedes ML320. Intel D201GLY2,1024mb DDRII,120Gb S-ATA HD,HQCT,7"Touchscreen,2x 7"build in headrest screens,OBDII reader,Mauri skin.
seninha is offline   Reply With Quote
Sponsored Links
Old 02-19-2008, 08:40 AM   #2
seninha's Avatar
My Photos: (0)
Problem solved (by it self)
I just dont know what happend after I shut it down the system. This because while starting the car to get to my work , suddenly there was sound comming out of my speakers
And this after many reboots trying to make the powersupply to start my amp.
So , please close this topic as problem is solved
(by it self )
Well, it seams that the problem is not gone.
Because I had my case lying around in my boot I did get back to my car to put it onhis normal place.
I disconnected all cables , included powerline.
Place the case back and reconnected everything.
Started the car and gues what......NO SOUND came out of the speakers .
I really think now that there is something wrong whit my M2-ATX.
Will it be possible to connect the normal 12V line directly to my remote cable , just to see if this will power it up??
Gods right foot!!
Old 02-19-2008, 01:03 PM   #3
rgarjr's CarPC Specs
rgarjr's Avatar
Vehicle: 98 Lexus GS300
My Photos: (26)
Do not hook up 12V battery to your remote out on your PSU, you will mess it up. Maybe you need a relay.
rgarjr is offline   Reply With Quote
Old 02-19-2008, 02:35 PM   #4
seninha's Avatar
My Photos: (0)
OK, but what kind of relay (i'm a nooob concerning this) and how do I attached this??
Gods right foot!!
Old 02-19-2008, 04:15 PM   #5
rgarjr's Avatar
My Photos: (26)
Just a standard automotive relay. The relay has 4 contacts labeled 30,87,86, and 85. On 30, you hook up 12V battery. On 87 you hook up the remote wire out to your amp. On 85 you hook up to ground. On 86 you hook up your remote output from your PS.
Actually the relay has another contact which is 87A which you won't be using.
Old 02-19-2008, 05:17 PM   #6
seninha's Avatar
My Photos: (0)
On my way home from work after starting the engine the amp did power on normally
It seems that the problem only appears when I start the CarPC when the engine is off.
I think I will have to get me a relais.
But an other problem just appears.
because I wanted to test if the amp did only start up when enigne was running , I shut it down and started the PC by moving the starter key to position one.System powerd op without sound, so amp didnt go on like i suspected.
Now the next problem appears, when I turned the key to the OFF possition,PC did't go to hibernate like it should
I think that both problems are M2-ATX related.
This because the last couple of days , while installing and testing the system in my house using a normal PSU the system hibernated everytime I asked for.
If this continue then I think I need to return the PSU to the Sates
Gods right foot!!
Old 03-12-2008, 11:58 PM   #7
stangg172006's Avatar
Vehicle: 2006 VW Rabbit
My Photos: (0)
sorry dont mean to hijack but what are you using to connect the two pins on the m2-atx to your amp? did it come with the psu or did you have to buy/fab your own?
'08 VW Rabbit S 2.5
Carputer Progress:
Design:[][][][][][][][][][][][][][][][][][] 100%
Fabrication:[][][][][][][][][][][][][][][][][]75%
Installation:[][][][][][][][][[][][][][][][][][][][][][][][][][] 0%
Carputer on hold!
stangg172006 is offline   Reply With Quote
Old 03-13-2008, 06:24 AM   #8
proph's CarPC Specs
proph's Avatar
Vehicle: 1999 Dodge Dakota
My Photos: (0)
The M2's that I've seen didn't have enough current to fire on a standard automotive relay. I recommend using an optical isolater that will turn on w/ anything from 3-32volts, and some minute form of current. Part number is 70G-ODC5B. Good luck...
Setup:
Dynaudio 240GT
PPI PC4100, PPI PC2350
Zapco DSP6
ADS DAC
Testing new board (Albatron KI690-AM2)
"I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
proph is offline   Reply With Quote
Old 03-13-2008, 10:04 AM   #9
seninha's Avatar
My Photos: (0)
What I use is the same cable that I did when my M1-ATX was installed.
This cable is attached to the right pin, as its mentioned on the manual.
Amp only powers up when engine is running,that means that the 12v that are needed is supllied by the PSU at that moment
Gods right foot!!
Old 03-13-2008, 11:54 AM   #10
My Photos: (0)
thanks for the response! However, my concern is over how to actually connect the cable from the amp to the PSU. i know the pin is really fragile so i dont want to damage it. Did you solder it? use a connector of some sort?
thanks again!
'08 VW Rabbit S 2.5
Carputer Progress:
Carputer on hold!
Sponsored Links
Old 03-13-2008, 01:21 PM   #11
seninha's Avatar
My Photos: (0)
Cable is attached from the amp to the PSU using a fan connector.
Bu as the Amp is power up normally when engine is running but NOT when its off , it should be a PSU problem. Or at least the amp remote control.
I was talking to a friend of my and he thinks that the current coming form this remote connector does flow out somewhere. This because when I messure this connector then 12V is showed ,but when I connect the AMP cable this dropped to 8V.
I messure this with engine off.
Gods right foot!!
Sponsored Links
vB code is On
Trackbacks are Off
Hardware Review: M3-ATX Power Suply Bimmerstyle The Review Palace 8 03-05-2008 05:57 PM
Giving ITX and 300w ATX setups, capabilities of a laptop? Vineet Singh General Hardware Discussion 0 10-15-2006 01:12 PM
What size inverter for 200w PC power supply? plus ATX shutdown question JiminyC Newbie 8 08-22-2005 11:43 PM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 09:29 PM
fs: mastero mk-3.5 120w atx dc-dc power supply infinkc Classified Archive 7 05-16-2004 06:06 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
