Old 02-27-2008, 02:11 AM   #1
pnyboy27 is an unknown quantity at this point
additional power supply for clearwire modem?
im thinking about getting clearwire for my car so that i am able to have wireless highspeed anywhere i go in my car. i right now, i am running an aopen minipc with a lilliput touch screen. i have two usb hubs, one just for occasional uses in the center console for ipods, thumbdrives, etc. then one main usb hub which has the gps receiver, usb touch screen, usb radio, bluetooth, wifi, and wireless keyboard/mouse.
for my psu, i have the carnetix p1900, soon to install the p2140 with the additional 5v regulator for the main usb hub. so basically my psu is powering the usb hub, screen, and pc. the clearwire modem is a 12v system, and i was wondering, would i need an additional psu just to power that? or is there any way i can have it so that its also powered by my current psu? what would you suggest for my plan? can i run two 12v systems off the one 12v outlet? or would that be not enough power then to run my screen and modem? thanks for any help in advance!
pnyboy27 is offline   Reply With Quote
Old 02-27-2008, 08:28 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
AS long as it doesnt overlod the PSU that you're using now, you could tap it for 12v for the clearwire unit.
Use yellow & black from a HDD power connector.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 02-27-2008, 02:14 PM   #3
how would i know whether it overloads the psu or not?
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
Power Supply MrGee Newbie 9 06-21-2006 05:44 PM
power inverter power supply shutdown problem launter Power Supplies 10 09-21-2005 12:12 PM
Power Supply Options? Optikal Power Supplies 9 06-26-2004 06:46 AM
AT power supply questions JustAGuy General Hardware Discussion 4 07-26-2000 05:35 AM
