The MP3car.com Store
Thread Tools Display Modes
Old 05-03-2008, 01:00 PM   #16
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
Quote: Originally Posted by conjur View Post
Hmmm... I must be missing something here...
I've always used a car battery charger, set on low... it outputs around 14 volts, but all my stuff has always had internal power regulators anyhow...
I picked mine up from autozone, or something like that, for $30...
peace
Mike
Me too. Worked well for over 6 years so far : http://www.mp3car.com/vbulletin/powe...wer-house.html
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Sponsored Links
Old 05-03-2008, 03:05 PM   #17
blackcobra487's CarPC Specs
Vehicle: 03 Accord
My Photos: (7)
I don't understand the issue either. If I had to do any bench testing I would simply use a battery charger. It seems that it works for other people, so that's going to be what I do if I need to.
blackcobra487 is offline   Reply With Quote
Old 06-23-2008, 05:02 PM   #18
Ricksastar's Avatar
Vehicle: 2006 Ford Explorer
My Photos: (0)
would this work for bench testing?
http://www.autozone.com/R,NONAPP3042...ductDetail.htm
Ricksastar is offline   Reply With Quote
Old 06-23-2008, 11:11 PM   #19
conjur's CarPC Specs
Vehicle: 1999/Honda/Prelude
My Photos: (0)
Ricksastar: That looks like it should work, so long as it doesn't have an "auto off", that turns its self off when the battery is full (trust me, the auto off function causes heartburn... I thought I fried my PIC sooo many times, when nothing would work, till I realized that I stopped getting power, lol)
Not really sure if mine uses some sort of auto off, or if its just the fact that I'm pulling more current than it can supply... but either way, it's been a good testing tool, and has yet to let me down (*jinx's self*)
peace
Mike
conjur is offline   Reply With Quote
Old 06-24-2008, 06:46 AM   #20
Ricksastar's Avatar
My Photos: (0)
sweet! thanks for the feed back Mike appreciate it. Gonna put it all together tonight and give her a test run... fingers crossed.
Sponsored Links
Old 06-24-2008, 08:45 AM   #21
Rick99TAWS6's CarPC Specs
Vehicle: 2000 Pontiac TransAm WS7
My Photos: (0)
I first used just a battery charger hooked to a M2ATX for bench testing the system and it worked fine - after going through USB devices not always working properly switched to a DSATX and the manual said not to do that......... put a 12V battery in between the charger and the carputer and that worked good also - not sure why the DSATX manual says not to use straight off of charger, but better safe then sorry.............
Rick99TAWS6 is offline   Reply With Quote
Old 07-11-2008, 05:51 PM   #22
BlazingBird's Avatar
My Photos: (0)
Rick99TA
Hey Rick,
Hows it going? I too have a T/A. I love it. I am looking at the same problem here. I would like to run my carputer off a batter charger. I have the M2ATX. Did you say you were going through USB devices as if you were tearing them up by using a battery charger?
I think i'm going to try to hook up to my battery charger tonight to play with settings.
I am trying to get my wireless network at home to work in my car while its in the drive way or gargae. I recently moved my wireless router and still nothing. I need some more time while working on this, so I need a power supply from the house. Your response will be greatly appreciated.
Wes,
BlazingBird is offline   Reply With Quote
Old 07-14-2008, 07:05 AM   #23
My Photos: (0)
Wes,
Sorry bout the delayed response - busy weekend
Nope - think I was actually short on 5V power with the M2ATX, running touchscreen and wireless keyboard and indash DVD/CD player and GPS and wifi and HPTuners interface(for tuning LS1/4L60E ) with USB and sometimes the USB stuff would act weird..... seems better now with the DSATX(more 5V) but I am now actually running the M2ATX in the dash and using it to power the screen, indash DVD/CD, and eventually a USB port
M2ATX was fine in the house using a 12V battery charger but I did not hook everything up in there, mainly used it to test main stuff(board/CPU/PSU/DVD/etc) and load up the software
Having some wifi difficulties here lately(think card may be on its way out), but can usually pick up the signal okay in the driveway
And gotta say - bird lover here, still have the first car I bought - '67 Firebird(bought in 1980 - dating myself here)
Sponsored Links
vB code is On
Trackbacks are Off
DC Input AC output using MPI-400 sathish17110 Power Supplies 1 12-27-2007 10:43 AM
dc - ac power inverter dasaint80 Power Supplies 3 12-10-2005 03:16 PM
new 200 watt PW200M DC DC converter? Xtreme2k2 Power Supplies 10 06-06-2004 04:04 PM
FOR SALE: DC-DC Converter: 24v input, +12v -12v +5v output, 68W, small! Mad Jad Classified Archive 5 08-20-2002 08:29 PM
why not to use zener to make 12V DC?? embedded Power Supplies 4 04-26-2001 08:54 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
