Notices
Old 03-03-2008, 12:29 AM   #1
ronjon228's Avatar
System Specs, M2-ATX compatible?
I've read up on the forums and checked some PSU calculators, but don't know if an M2-ATX will power my CarPC. Here's the specs:
1.8GHz P4 Northwood (47 watts TDP)
Gateway OEM #4000792 Mobo (Intel D845GRG)
512MB DDR266 (1 stick)
Sound Blaster Live! OEM PCI
3.5" IDE HD x 3 (1 20GB, 2 40GB)
I realize that using 3 HD's takes my consumption up a bit, so if I had to, I'll just get 1 big IDE drive and switch over to that. By all my calculations I believe the M2-ATX should be fine with the current setup. Just looking for people with similar systems running them off this PSU.
Just did a mock up, here's what I came up with:
CPU: 50watts
Mobo: 30
RAM: 5
HD: 45
Sound: 7
Fans x4: 12
Total: 149watts
This is also going on the HIGH end of the component ratings I could manage to find. Seems the M2-ATX should suffice. Especially if I drop down to 1 HD, or 2 at the most. What do you guys with similar parts/knowledge/experience think?
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
ronjon228 is offline   Reply With Quote
Old 03-03-2008, 10:42 PM   #2
just keep in mind that it's not only the total wattage of the setup, but on what rail also....you could overload a particular rail and fry the PSU even if you don't overload the 160Watt the M2-atx puts out...
that and just use 1 hard drive... takes up less space, less power consumption too....
plus, keep in mind the screen if you'll power it off the PSU, and the USB connections...my setup calls for a GlobalSat USB nav dongle, my touch screen relies on a USB port to function also... if you use a wireless mouse/kb..... don't forget to add all that stuff up....
CTdubbin is offline   Reply With Quote
Xbox w/ M2 ATX and PSU convertor MiniRX7 Power Supplies 1 11-25-2007 07:45 AM
where to get specs for ATX system ? felix99 Power Supplies 2 02-26-2003 07:08 PM
Proposed system specs HWExtreme General Hardware Discussion 5 12-12-2001 09:33 PM
micro / mini atx system w/ LCD and all the goodies gizmomkr Classified Archive 8 05-09-2001 04:08 PM
DC-DC pwer Supply for an ATX (P2)system or maybee a P-III system? Bloomk General Hardware Discussion 3 01-18-2000 02:34 PM
