You need to have the psunomi software running, it actually tells the OS to hibernate when the 2140 sends the ACPI signal to the computer's USB port.
This acts the same way an uninterruptable power supply works for a server.
If you are forcing hibernate and its not properly, well then I don't know.
Also make sure your bios is set properly, my Acer P1000 was a biotch to get right, and I still have cold weather problems, not the 2140's fault, but the internal PS on the P1000.
Hope that helps.
TruckPC, BoatPC, and CarPC I need a life!
