Old 03-21-2008, 06:13 AM   #1
ax_foley's Avatar
P2140 Fast Led Flash - Drive me crazy :-/
Hello everyone, I'm quite new to this forum but have been watching and learning from them for a few months now..
I've decided to go down the laptop route for my install, a Thinkpad T42
I've recently purchased a new 2140. I'm using a desktop PC PSU for testing purposes.. When I attach the +12v the status LED flashes "medium" speed 5 times then starts to flash rapidly until the power is turned off to the 12v circuit - it never behaves like the "normal LED behavior" video from the Carnetix web site.
I've read through the forums and upgraded the firmware as suggested, but that doesn't work. The PSU monitoring software reports there is a USB cable attached to the device and works correctly as I've done the latest firmware and software installation.
I'm completely stumped and slowly getting frustrated.
Can someone please offer any help at all?? I'm pretty sure it's my wiring but I need some expert help.
Many thanks in advance..
Ax
CarPC in development for.. MkIV VW Golf GT PD GTI TDI 150 (190) - Now that's a mouthful.. but it goes like S***!
ax_foley is offline   Reply With Quote
Old 03-21-2008, 10:53 PM   #2
rgarjr's Avatar
Try hooking it up to a car battery see what it does. I'm thinking it doesnt like the voltage coming in from the PSU u have hooked up.
My carpc worklog
rgarjr is offline   Reply With Quote
Old 03-22-2008, 04:12 AM   #3
ax_foley's Avatar
Hi there, thanks for the reply. That does seem to be a popular response and I will try it ASAP. Is there such a device as a car battery desktop siulator?
Thanks again..
Old 03-22-2008, 05:09 AM   #4
Fusion Brain Creator
2k1Toaster's Avatar
Well the method is what you are doing, using a Desktop PSU with pin 14 shorted to ground on the ATX connector.
Is there a reason that you cant just plug it in to your car? Pop the hood (or bonnet ) and wire it up just to see. But if you have a desktop PSU going and it is the only thing powering the 2140, then it probably wont help.
Old 03-30-2008, 05:21 AM   #5
ax_foley's Avatar
All sorted now thanks to all. It was simply because I was using a 12v input from a PC desktop PSU. I bought a 13.8v from Maplins and it worked first time.
Thanks again.
AX
All-electronic flash drive and solid state hard drive Typhoon747 General Hardware Discussion 12 12-12-2003 02:20 PM
External notebook hard drive help mtmsol General Hardware Discussion 4 04-18-2002 12:24 PM
Flash hard drive on ebay Mp3 V General Hardware Discussion 22 02-16-2002 11:39 AM
Hard drive LED constantly on! AndyM General Hardware Discussion 5 01-11-2002 07:18 PM
how to make LED flash? schrodos General MP3Car Discussion 7 01-14-2001 06:39 PM
