The MP3car.com Store
Thread Tools Display Modes
Old 03-27-2008, 02:51 AM   #1
My Photos: (0)
AVR based laptop startup/shutdown controller
I'm going to be using a laptop in my latest carpc, unfortunately its battery is totally dead so I'm designing a startup/shutdown controller which will act in very much the same way as the normal pc car power supplies.
When it senses ignition it will start the pc up by connecting some relays, when ignition is lost it will shut the pc down and after about 30 seconds will kill power totally to stop the pc draining the battery.
This is my schematic so far, anybody have any suggestions / comments?
Shad0wca7 is offline   Reply With Quote
Sponsored Links
Old 03-27-2008, 04:33 AM   #2
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
Instead of daisy chaining the relays for the main power like that, why not just use a transistor to switch the larger relay. I assume you did it that way because you didn't think the AVR output could drive the large relay directly. It's clunky the way it is.
I think you chose a device with a few too many IO pins, also. My first shutdown controller used a 12c508 (8 pin device), my next one (which includes a bunch of I/O and servo controllers) uses only a 16 pin device (16f88 IIRC). A 40 pin device is huge for such a simple task.
D2 is kinda redundant. I usually do reverse polarity protection by relying on the fuse popping when the zener forward conducts (or another diode in parallel). This just reduces the voltage drop before your circuit gets the juice (all kinda academic since you are using a linear regulator anyways).
You might want to put a pull down resistor on ignition sense too.
Relays are noisy for switching. A lot of power-switch-press circuits just ground out one of the power switch leads with an NPN transistor or FET. Much cleaner design that way, and less noisy, lower power, smaller, more reliable, etc... Similarly for the main power switch. Might I recommend a high side driver or FET.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 03-27-2008, 06:56 AM   #3
My Photos: (0)
Thanks for the input Rob, some great suggestions which I'm going to use so standby for a redesigned version using transistors. Although won't there be the risk of a massive transient going through the transistor which will be activating the laptop PSU relay?
The Mega16 is WAY overspecced for this I agree, there are 2 main reasons I am using it at the moment: 1) I have a few of them lying around 2) I have a Tiny84 which I will probably be using (even that is overkill) but I don't have an Eagle library for it.
I was going to use the internal pull-down resistor for ignition_sense, I also figured that D2 won't harm (and won't cost me anything) so any extra protection is worth a squirt.
Old 03-27-2008, 07:10 AM   #4
Raw Wave
Rob Withey's Avatar
My Photos: (0)
Snubber diode? I just assumed you omitted them because they are always taken for granted with inductive loads (even your small relays will have some inductive kick on release).
Old 03-27-2008, 07:13 AM   #5
My Photos: (0)
Actually I forgot to add them for the relays!
What I meant on my previous post was possible transients coming from the actual car power source which the transistor will be connected to?
Old 03-27-2008, 07:25 AM   #6
Raw Wave
Rob Withey's Avatar
My Photos: (0)
If you're not comfortable designing with transistors then stick with the relays.
I don't know what you are referring to with the transient thing. Just get a transistor that can handle sufficient Vce (assuming bipolar) involved. I'd switch that relay with an NPN bipolar with the emitter grounded, suitable base resistors and relay coil between the collector and power source. When the base saturates, the collector goes to about 1 diode drop above ground and the relay switches. Whatever you do, don't go for an emitter-follower when switching with logic levels - big waste of time.
Actually, I wouldn't (and didn't) swtch a relay. I use a high side driver.
Old 03-27-2008, 07:30 AM   #7
Raw Wave
Rob Withey's Avatar
My Photos: (0)
More info on the high side driver I use. It's a VN30N. This is the datasheet :http://www.ortodoxism.ro/datasheets/...cs/mXryrqt.pdf
Old 03-27-2008, 07:33 AM   #8
My Photos: (0)
The high side driver is pretty impressive, I think for now though I'm going to stick with using transistors and relays, I have not really used transistors before so now is a goot time to learn and apply. New schematic coming soon.
Old 03-27-2008, 08:03 AM   #9
My Photos: (0)
Ok, how does this look:
I decided I didn't want to rely on the internal pulldown so added one. The cascaded relay is no longer present, instead driven by a transistor that should have no problem driving the coil. Snub diodes have also been added.
I'm not sure how to go about removing the power switch relay alltogether and replacing it with a transistor to short the contact... do you mind giving me a few pointers with that?
Old 03-27-2008, 03:47 PM   #10
Raw Wave
Rob Withey's Avatar
My Photos: (0)
Looks good.
Most power switches are between a signal line and ground. You can replace them with an open collector NPN transistor just like the ones you are using to switch the relays.
The relay is more portable in that it will work when the power switch is not configured in this way - might be best to stick with the relay.
Sponsored Links
Old 03-27-2008, 05:34 PM   #11
My Photos: (0)
I think I might be getting slightly confused about using the transistor to short the wires, would this work correctly or am I on totally the wrong path:?
Old 03-27-2008, 07:07 PM   #12
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
I think you should add a few simple things that you could implement later in code, like a little resistor divider to constant on ADC0 to monitor the battery voltage since yours is dead. Then put IGN on ADC1. A button for manual startup/shutdown. An LED for some feedback. And use the serial I/O for talking to the PC. You'll have more ideas after that.
XPort 1.22 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 03-27-2008, 10:42 PM   #13
Vehicle: 2000 VW Jetta VR6
My Photos: (3)
wow, I'm surprised you ended up using such a weird solution for power button driver. First of all, the power button will accept standard ACPI signal, and since you work with 5VDC already, all you need is just one tiny transistor with pull-up resistor that will make ~0.5ms 0V pulse.
Instead of regular relays, I'd use solid state relays that typically can handle at least 10Amps, you don't need any high-end SSR, just get the cheapest one with triac output.
Your avr may die if you use relays directly, either from overcurrent on IO line or voltage peak from coil transient.
Since you use avr, you can actually implement your battery voltage monitoring (avr has ADC inputs), I think it could be cool feature.
Look also for AVR Butterfly, it's a cheap development board with LDC display and atmega169, it would simplify whole project a lot.
EPIA TC 1G 256MB 60GB Linux,WindowMaker, Roadnav, Xine, XMMS, iGuidance3
Lilliput 8", Pharos i360, WUSB11v2.6 WiFi
dupa2 is offline   Reply With Quote
Old 03-27-2008, 10:55 PM   #14
Curiosity's Avatar
My Photos: (3)
Actually, all you need is a diode for the power button. If it works like a PIC, and I think it does, when off and set to output a digital line pulls to ground with the internal transistor. You just have to make sure it's on the whole time when the main relay is on. I used that for 8x8 LED matrix displays.
Old 03-28-2008, 02:28 AM   #15
Raw Wave
Rob Withey's Avatar
My Photos: (0)
That's about what I use. The pullup is on the motherboard though, and the grounded switch line is not needed (only one line is needed).
Like the circuit he posted above?
Like the high side driver I linked to (VN30N).
True, if you can get it to pull low enough.
Sponsored Links
vB code is On
Trackbacks are Off
startup/shutdown controller for laptops available? ideal2545 Laptops, Tablets, UPMCs, etc. 1 08-25-2006 05:50 PM
Newbie asks ? Laptop based carputer vs desktop pc based carputer SAScooby General Hardware Discussion 2 03-01-2004 01:59 PM
Anybody want to show a laptop based setup? blaster General Hardware Discussion 8 12-19-2003 07:08 PM
OPUS startup/shutdown controller problem... rbarr110 Power Supplies 1 11-14-2003 11:38 PM
mp3 player kit / controller based Talldude4evr General Hardware Discussion 2 06-05-2003 09:02 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
