So I just got the DSATX in last night and I hooked up to up to my new carPC (haven't installed it yet). It's a MSI Fuzzy RS690T. Right now I'm just bench testing it and to install everything before it goes into the car. I connected it to this power supply:
http://www.universal-radio.com/catalog/hamps/2423.html
From what the DSATX manual says, that should be enough to power it. I'm using 12 gauge wire.
Anyways, I connect the DSATX to the motherboard (20-pin and 4-pin headers, power switch (verifying polarity), no other load off the DSATX), put the DSATX in dumb PS mode and turn it on. The DSATX LED comes on solid, CPU fan spins for about 1-2 seconds, then it stops spinning and the DSATX LED goes completely out.
Next, I decided to plug in a fan on the DSATX fan header. Turned it on again and the DSATX fan spins up fully and during the 1-2 seconds its speed slows down and speeds up erratically and then it dies just like the CPU fan.
I then rotated P2 fully CCW and tried the same thing with the same results.
I can only think of 2 possible causes:
1) The AC-DC PS I'm using isn't putting out enough for the DSATX which would surprise me based on its specs.
2) The DSATX Is at fault.
Help please.
