Go Back   MP3Car.com > Mp3Car Technical Hardware > Power Supplies
Old 04-05-2008, 03:45 PM   #1
hailrazer's Avatar
hailrazer is an unknown quantity at this point
HP Slimline with 160 watt Power Supply. How do I hook this up in car?
Well I bought a HP Slimline A3300f .
It has a 160watt power supply in it .:
It has a 24 pin connector and two harddrive connectors and that's it.
It basically looks almost identical to this one :
Now I am a complete Newbie when it comes to powering this in the car but I know I don't want to use an inverter. And I would like it to hibernate when the car is off, turn on when the car starts , etc.
What do I need, Opus, M2-ATX ?
Someone Please help me.....
hailrazer is offline   Reply With Quote
Old 04-06-2008, 08:55 PM   #2
hailrazer's Avatar
OK I think I have it figured out.
I need a M4-ATX .
It has the 24 pin ATX Power connector and the two hard drive connectors.
Remove old power supply and hook the M4-ATX up . Also hook it up to the motherboard turn on/off switch.
Does that sound right ?
Old 04-08-2008, 11:41 PM   #3
blackcobra487 is an unknown quantity at this point
The M4-ATX will do the job, but it isn't needed unless you need that much power. I believe it puts out 250watts, I could be wrong, I'm just too lazy to look right now. You could power this with an M2, you would just need a 20pin ATX to 24pin ATX adapter. They're not too hard to find. One thing you need to know about HP, that 24pin connector isn't a standard ATX plug, meaning no matter which of these PSUs you decide to go with, it won't plug into the mobo. I have heard that the HP plug is just a smaller version of a 24pin ATX plug. If this holds true, all you would need to do is cut the connector off the current PSU and hardwire it into your new PSUs ATX connector. Other than that, you seem to be right on track.
I'm also a bit of a newb, but I did manage to get my first install working. That says something. I have learned that HP/Compaq are a pain to work with. My original system was a Compaq Deskpro. That sucker had a 14 pin connector which I had to make an adapter for. I gave up and bought a standard Micro-Atx mobo. It works pretty well, except Windows98 didn't pick up some drivers and I can't seem to find them.
blackcobra487 is offline   Reply With Quote
Old 04-09-2008, 07:18 AM   #4
hailrazer's Avatar
Thanks for the advice.
I figured I needed the 250 watt because I upgraded the video card to a Geforce 8400. And I'm adding a Lg Blu-Ray/Hd-Dvd drive.
And I read somewhere else about the nonstandard 24 pin plug, so I guess I'll have some wiring to do.
Thanks again.
Old 04-09-2008, 10:09 PM   #5
hailrazer's Avatar
Alright. 24 wires / 24 solder points / 24 heat shrinks later :
And here it is plugged up where the 160 watt factory PSU was.
Old 04-10-2008, 04:57 PM   #6
hailrazer's Avatar
I got my M4-Atx in a project case and wired up
http://www.mp3car.com/vbulletin/powe...enclosure.html
Old 04-23-2009, 09:30 PM   #7
Ringfinger69 is an unknown quantity at this point
Hailrazer Please check your inbox
Ringfinger69 is offline   Reply With Quote
How do I power a carputer cube/gaming pc? cortewardy Power Supplies 4 01-20-2008 08:00 PM
When do you switch the power on/off ? duffman_jr Newbie 1 11-14-2007 10:50 PM
Carputer Setup and power rewquirements driller Newbie 4 10-08-2006 03:15 AM
Power inverter on/off switch question Skipjacks Power Supplies 41 01-22-2005 12:33 PM
what to power my carputer? Seabass General Hardware Discussion 11 09-27-2003 11:04 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
