Notices
Old 04-07-2008, 01:05 AM   #1
PSU Recommendations for a picky engineer
Hi - I've been looking around for some time to find a good candidate for a power supply for my car PC, but haven't been able to find what I want. I am powering an IEI Wafer LX800 SBC (+5V only, supports AT or ATX power).
  • +5V (3.5A) regulated outputs
  • Ability to turn on either with the ignition or when I unlock the car remotely (i.e. sensing door unlock pulse)
  • Auto shutdown after preset time if turned on with door unlock pulse (and ignition never turned on)
  • Ability for the SBC to prolong shutdown time after ignition turned off (i.e. when I park in my garage, I want the PC to sync my music over WiFi, and it may need more time than the standard shutdown timeout allows)
The Carnetix P2140 box is close, as it has the unlock pulse input and the ability to prolong shutdown, but it doesn't have the required capacity on the +5V rail (although I could potentially use a DC-DC on the +12V output). Also, this thread puts me off.
I also looked at the M2-ATX, because I could then write custom firmware to support the behaviour I'm after (using, e.g. the jumper pins for the unlock pulse and prolong shutdown inputs). I presume that the firmware here is current - anyone know different? It looks like a chap called FMode has done something like this here.
The M4-ATX looks interesting with the USB interface, which might allow interaction between PC and PSU for my prolonged shutdown mode, but I didn't see anywhere how the interface works or whether you can have custom firmware (this thread may turn up something soon).
Does anyone have any other suggestions?
Thanks,
Matthew.
mpr90 is offline   Reply With Quote
Old 04-07-2008, 01:32 AM   #2
Thanks,
Matthew.
The CarNetix unit is as close as you're going to get for the requirements that you have. (maybe they'll custom build you one so you can get that extra 0.5 amp out of the secondary circuit)
Rest assured regarding that thread about their poor support ... the device speaks for itself ... I have had one for almost a year now, and no problems whatsoever. If you understand electricity, then you'll have no problems with the 2140, IMO.
perk03z06
Windows XP PC
InTruckPC
P4 3.0 GHz Hyperthread CPU, 1Gb RAM, 120 Gb Hard Drive, DVD/CD-RW, Centrafuse XLE 1.47, 7" Xenarc, GPS, EV-DO via Samsung i730 ... more coming!
perk03z06 is offline   Reply With Quote
Old 04-07-2008, 03:57 AM   #3
Fusion Brain Creator
2k1Toaster's Avatar
Well nothing currently sold does what you want. So you are faced with 2 options: (a) code custom firmware, or (b) build custom hardware.
So you like soldering or flashing?!
I think coding would be the easiest and cheapest. Get the M2, and write your own firmware for it. With the M2 you have a ton of options for other hardware. With the carnetix and using all its juice, you are pretty much done for with peripheral devices.
Old 04-07-2008, 04:18 AM   #4
Raw Wave
Rob Withey's Avatar
Custom firmware/hardware all the way. I recommend the Texas Instruments ISRs for regulators. I run a PT6625 for a 5V supply (and PT5071 for 12v). They run nice and cool.
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 07:25 PM
Arise PSU problem! mobileh1 Power Supplies 13 06-25-2004 11:14 PM
hooking up my arise PSU....? jusatry General Hardware Discussion 4 03-13-2004 08:53 PM
What to look for in a PSU some info for you cproaudio Power Supplies 9 04-04-2003 02:07 AM
mircoATX PSU? ODYSSEY General Hardware Discussion 7 03-12-2001 03:30 AM
