The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 04-08-2008, 06:28 PM   #1
treetop777's CarPC Specs
treetop777's Avatar
Vehicle: 1981 Ford F-100
My Photos: (0)
M2-ATX Ignition override LED
Forgive me if this is not the right place to ask this.
I'm going to incorporate a switch to override the M2's shutdown when the ignition is turned off. I want an LED to come on when it's in override but i'm not sure the wiring in this diagram is right, is it? For some reason it don't seam right.
Thanks in advance.
treetop777 is offline   Reply With Quote
Sponsored Links
Old 04-08-2008, 09:28 PM   #2
Bullwinkle777's Avatar
Vehicle: 91 Honda Civic Si
My Photos: (0)
Run a constant 12v to and from your switch. The way you have it ran, as soon as you turn off your car, the switch will not work. And don't forget a resister for the LED. I'll draw somthing up for you, if no one else beats me to it .
Bullwinkle777 is offline   Reply With Quote
Old 04-08-2008, 10:53 PM   #3
JimmyFitz's CarPC Specs
JimmyFitz's Avatar
Vehicle: 2002 Thunderbird V8
My Photos: (0)
examples
Thanks in advance.
Here's a simple manual one:
http://www.mp3car.com/vbulletin/242524-post7.html
and an auto-resetting one with LED:
http://www.mp3car.com/vbulletin/720318-post32.html
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 04-09-2008, 08:37 AM   #4
treetop777's Avatar
My Photos: (0)
I had a feeling it wasn't as easy as my simple diagram
Thanks for the replies. I still welcome any other sugestions.
Old 04-09-2008, 11:37 PM   #5
JimmyFitz's Avatar
My Photos: (0)
Can be simple
It is almost that simple:
~Jimmy
Old 04-10-2008, 11:53 AM   #6
treetop777's Avatar
My Photos: (0)
Thanks, i can't say i fully understand that diagram. It did however (in conjunction with the other examples) got me to thinking i realy do need a on/off/on swith, not just a on/off.
I'll rethink it and see what i come-up with or just abandon the idea.
Thanks very much for your help.
Old 04-10-2008, 03:37 PM   #7
JimmyFitz's Avatar
My Photos: (0)
The last diagram I posted uses a DPDT switch with center off. The switch is shown in the override position which routes 12V to the PC so it will stay on. It also sends the same to the LED and its series limiting resistor on the second pole. When the switch is moved to center, the PC is disabled and won't turn on at all. The top position for the switch is the normal operation where the PC turns on and off based on the status of the ignition switch.
~Jimmy
Old 04-10-2008, 05:10 PM   #8
treetop777's Avatar
My Photos: (0)
I appretiate your efforts to get it through my thick skull but i just don't don't understand how to connect the wires (mainly going to the LED) by looking at the diagram; with my limited knowledge reading (electronic) diagrams, you almost have to spoonfeed me where each and every wire goes or i will surely screw it up
Thanks for your help.
EDIT: After looking at JimmyFitz's diagram for about a week, it finaly dawned on me!
Here it is wire-by-wire and it works beautifully.
P.S. heed the warning about the resistor on the LED!
Old 04-23-2008, 12:57 AM   #9
My Photos: (0)
Hey treetop777...I got it working now. I pick up a (680 ohm resistor) and a (DPDT mini center-off toggle switch). This switch have 6 pins on it and you have to use the 2 first pins and the 2 middle pins. http://home.austin.rr.com/soloxp/ima...T%20Switch.JPG
Thanks man.
soloxp is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
M2 ATX Amp turn on not working CdRsKuLL Power Supplies 21 10-30-2007 09:31 AM
Powerin the LCD with the M2 atx luckyno LCD/Display 2 01-20-2006 01:14 PM
Wtb: M2 Atx EsKALad Classified Archive 1 01-03-2006 08:59 AM
morex 80wpsu and reg ATX cable dilema!! surfy Power Supplies 1 08-16-2005 08:06 PM
Mastero MK-4 ATX PSU Semi kit for SALE Mastero Classified Archive 4 06-10-2004 01:42 PM
Sponsored Links
Ad Management by RedTyger
