That burned surface-mount component is really a transistor (N-channel FET), even though its package looks like an IC (notice the silkscreened label Q4 rather than U4).
It's identical to Q3, on the other side of coil L1 in the square gray can.
Full markings:
F (Fairchild logo) AG1AN
FDS
6680A
Datasheet at
http://www.fairchildsemi.com/ds/FD/FDS6680A.pdf
Since it's really just a 3-terminal device (top 4 pins tied together as Drain, 3 of 4 on the bottom as Source), if you locate a matching FET in some other case, like a TO-220 it should be possible to bend the pins and fit it in.
Of course, there might be something else wrong that caused that FET to blow in the first place... it's part of the +12V buck/boost regulator circuit, if that's any clue.
Good luck!
