more M2 issues.... ;-(
Ok.. so I've decided to put up with a non functioning J8 by using a button at the dash.. now that I have it installed in my voom 2, I have a new issue...
When I press the power button, it turns on.. then right off.. press it again and again... on.. then off.. Now, if I disconnect the harness, and reconnect it, i can press the power button and it turns on.. oddly enough as short a period as it is... when it does power on, i get a message during boot up stating that the computer was previously shutdown due to a thermal issue (overheating)
I have the m2 connected as follows:
red - constant
white - constant
black - ground
J8 - n/c
J9 - n/c
mobo on/off - to dash
amp remote on - via dash switch.
voom2pc
mobo: intel d201gly2a *fan cooled*
2.5" 120 sata drive
1 gig ram
rogers portable internet running off the 12V rail (disconnecting makes no difference)
What other options do i have for power inside a voom2 pc enclosure if I have to buy another one ?
