The MP3car.com Store
Thread Tools Display Modes
Old 04-24-2008, 09:58 PM   #46
Fox_Mulder's CarPC Specs
Fox_Mulder's Avatar
Vehicle: 2004 MR2 Spyder TTR
My Photos: (49)
I'm inclined to think it's a logic problem. if only the interface could be updated via usb we wouldn't haveto worry about RMAing these units.
Like I have a problem where when the M4 is in the HARDOFF state it wont send the motherboard pulse when ignition is applied. Details here
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353
Fox_Mulder is offline   Reply With Quote
Sponsored Links
Old 05-08-2008, 12:51 PM   #47
hailrazer's CarPC Specs
hailrazer's Avatar
Vehicle: 2007 Gmc Yukon Xl
My Photos: (0)
I just got my new M4-ATX power supply from mini-box installed.
And I am happy to say it works perfectly. Goes into hibernate in 5 seconds and the screen turns off
Everyone should try to get one with the new firmware. Mini-box is good to work with once you get them answering emails )
My 2007 Yukon XL setup. http://www.mp3car.com/vbulletin/show...64-5000-a.html
hailrazer is offline   Reply With Quote
Old 05-18-2008, 04:52 PM   #48
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Hey folks, I've just gotten one of the new M4-ATX's. After setting it up and putting the dip switches into the P1 configuration, I've bench tested it using a switch to simulate the accessory line.
Turning it on, it worked just fine and the PC booted without issue. Turning it off, however, it simply never turned off. It never signaled the pc to shutdown and never even cut the power off. Just stays on.
Has anyone see this behavior?
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 05-19-2008, 02:45 AM   #49
Fox_Mulder's Avatar
My Photos: (49)
Use a multimeter to check if the off pulse is actually being sent. Have you set the computer to turn off or hibernate when the power button is pressed in the control panel?
You may also need to change a setting that describes the behaviour of the power button in the bios. I had mine set on instant off and changed that to 4 secs then off. This is so when the power off pulse is sent to the motherboard the computer does not do a hard shutdown, rather windows can hibernate or shutdown gracefully - or I can manually bridge the power button connectors for 4 secs and have it do a hard shutdown.
Fox Mulder
2004 Toyota MR2
Old 05-19-2008, 07:41 AM   #50
Bugbyte's Avatar
My Photos: (19)
Interestingly, I've never been able to detect the pulse on the ACPI line using my multimeter. But I know it gets sent because the computer starts. I've got the meter set to 12v and am looking for a quick spike by measuring the voltage across pins 7 and 6 on J8, correct?
The power settings are set properly in the control panel (hibernate when power button is pressed) and this system was working fine with a Carnetix regulator just before putting the M4 on it.
Sponsored Links
Old 05-19-2008, 07:58 AM   #51
Fox_Mulder's Avatar
My Photos: (49)
Don't measure voltage, measure resistance. It should be infinite and then drop down to 0 and then go back up to infinity.
edit: If our multimeter is not fast enough (it is a 500ms pulse) the pulse may nto be recognised by your multimeter (unlikely) or the resistance value reported wont go all the way to 0 before going back up to infinity. As long as the resistance value lowers you can be sure the pulse is being sent.
Fox Mulder
2004 Toyota MR2
Old 05-19-2008, 08:13 AM   #52
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
An old analogue multimeter with a needle might be better to use than a DVM in this case.
Enforcer is offline   Reply With Quote
Old 05-20-2008, 05:43 PM   #53
Bugbyte's Avatar
My Photos: (19)
Okay, measuring continuity (doh!) I don't see any pulse at all, but when I touch the DMM leads very quickly I get a jump in the reading.
Also, if I short the jumper it starts up and shuts down properly and immediately.
I guess I don't understand how it could start but not stop?! I think I need to try out some of the other modes to see if the board is working properly.
Old 05-21-2008, 04:31 AM   #54
Fox_Mulder's Avatar
My Photos: (49)
lol You seem to have the very opposite problem I have, mine wont send the startup pulse but sends the shutdown pulse fine. I have set my motherboard to power on after power fail to overcome this. You could always rig a circuit up to have the igniton line conected to say your serial port and when the line goes low initiate the shutdown/hibernation sequence, but you shouldn't have to do that if your m4 was working correctly.
Fox Mulder
2004 Toyota MR2
Old 05-29-2008, 11:11 PM   #55
My Photos: (0)
So i think im having a similar issue as well,
When M4-ATX is in p1 mode, it sends the startup pulse after 5 seconds, (light flashes quickly, then starts up) But my volt meter tells me it doesnt cut the voltage to the on/off switch after its fired up like it should.
After its turned itself off, it waits 60 seconds, and tries to start itself back up, and so continues the cycle. Any thoughts on this guys?
Ive got the POS+ line connected to the IGN for simulation.
n8r4e3 is offline   Reply With Quote
Old 05-29-2008, 11:13 PM   #56
My Photos: (0)
If i pull the power on/off from the PSU after its tripped the on/off, it boots just fine. As soon as i plug it back into the PSU, its like im holding the power button for 5 seconds.
Old 05-30-2008, 03:29 PM   #57
Bugbyte's Avatar
My Photos: (19)
Yep, same problem. See my response in your other thread about turn-on difficulty with M4.
Old 05-30-2008, 06:04 PM   #58
My Photos: (0)
Awesome! for those who want to follow along,
http://www.mp3car.com/vbulletin/powe...problem-2.html
Sponsored Links
vB code is On
Trackbacks are Off
New PicoPSU-60 (6-26vdc input) ik632 Power Supplies 1 10-03-2006 11:18 AM
cant change skins??? Hell-Stopper FrodoPlayer 19 11-05-2004 10:10 PM
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 12:25 AM
Interesting problem trying to extend ATX switch InFix General Hardware Discussion 17 12-21-2002 02:52 PM
question about relays and high gauge wires Heedunk General MP3Car Discussion 12 05-10-2001 11:13 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
