Old 04-10-2008, 01:48 PM   #1
Noise issues with hardwired inverter
I get a ton of engine whine coming through my inverter. Whats the best way to kill the noise?
Only happens when my zune is charging.
Thanks!
Metalosophy is offline   Reply With Quote
Old 04-11-2008, 09:29 PM   #2
billmee's Avatar
So many questions
Where is the Zune connected for power?
Is the Zune also connected to your head unit?
How do you ground your pc?
billmee is offline   Reply With Quote
Old 04-12-2008, 01:39 PM   #3
Quote: Originally Posted by billmee View Post
So many questions
DC power to cigarette adapater -> inverter -> usb hub -> zune into HU.
No pc involved.
Old 04-12-2008, 07:32 PM   #4
Neither darque nor pervert
DarquePervert's Avatar
I suggest hard-wiring the inverter to the battery.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 04-13-2008, 06:41 AM   #5
billmee's Avatar
I'd ditch the inverter for a point of load source ( my hub needs 6vdc ).
You could probably find one at RadioShack for $20 that gives you the voltage/amperage you need.
Old 04-13-2008, 06:58 AM   #6
greatwhite's Avatar
way too many power conversions there..................
If charging the zune as simply as possible is your wish, just get a usb 5v cig lighter plug in. Radio shack has them for around 10 bucks..........
Used for ipods and such.
Cheers
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 04-14-2008, 12:07 AM   #7
The inspiration to install the inverter came from me being sick of only getting one usb port ala cigarette adapter. The noise remained just the same.
Suggest just butchering the hub for power only and hard wiring it in at a different location? What's wrong with my inverter to be more specific?
Thankyou very much.
Alternator Whine Only With Carputer tbird2340 Car Audio 25 06-29-2007 02:36 AM
Inverter now cauzing buzzing noise?? wtf? Yellow-Snow General MP3Car Discussion 3 11-11-2006 01:13 AM
Noise Cancellation Frequency Inverter Yevmeister Hardware Development 13 10-30-2006 09:50 AM
Problems with Xantrex inverter... RoyN Power Supplies 6 11-16-2004 06:26 PM
Inverter Noise Cherub211 Power Supplies 1 02-20-2004 12:09 PM
