Notices
Old 04-13-2008, 06:02 PM   #1
What Voltage would I use on a Epia Mini itx
My buddy passed away awhile ago and he was going to build a carputer.
He left a box of stuff at my friends house, and I found his Epia Mini itx motherboard. It has some type of car power supply on it, but it did not have the power cord. I was wondering what voltage I should hook up to it to make it work? Of course I would think 12 volts but then there is ampage, or maybe it uses a converter to just 5 volts? Any help would be appreciated.
Also, how would I know if positive goes on the outide or inside? Sorry to ask such newb questions.
ryan is offline   Reply With Quote
Old 04-13-2008, 06:14 PM   #2
SD beats everything. So there.
danielkh's Avatar
Sorry for your loss.....
Try to identify the PS. Look on this site, mo-co-so.com, or any other carputer site you can fine, and see if you can discover what kind it is. Then from the same site, you should be able to find drawings giving you pin settings, jumper settings, etc.
More than likely, it's 12V, but which pin is ground, ingnition, or battery.
Latest Install: http://www.mp3car.com/vbulletin/show...-part-3-a.html
My opinion is my own.
danielkh is offline   Reply With Quote
Old 04-13-2008, 06:24 PM   #3
danielkh's Avatar
If you still have no luck, I would suggest you take a picture and post it. Sure someone can identify it if you can't.
Old 04-14-2008, 11:57 PM   #4
Thanks for the info. I'm surpised I didn't see this sooner. It says PW-60B. I googled it but not too much came up. Some old links that didn't work.
Old 04-15-2008, 12:35 AM   #5
I found the manual.
http://resources.mini-box.com/online...W60-manual.pdf
I hooked it up to the motherboard with a 12v power supply. anyway to turn it on? I jumped the pins on the motherboard for the power switch but I get nothing. I tested the two prongs on the pw-60 and i'm getting power to it.
Old 04-15-2008, 12:55 AM   #6
wow, i just hooked up a 350w power supply to it, hit the power jumper and the fan started workign ont he motherboard. A few seconds later I heard a loud Whizzz..... and the power supply started smoking. I pulled the plug real quick on that.
Help in deciding Mini ITX board DrewSG General Hardware Discussion 1 12-08-2006 01:01 PM
Mini ITX or Micro ATX Dragonknell911 General Hardware Discussion 20 10-19-2006 09:19 AM
MINI ITX board llmask General Hardware Discussion 2 07-29-2004 11:26 AM
Connecting 2 x 7" TFT to Epia ITX Please help.. Lazyboy62 LCD/Display 7 07-22-2004 01:36 AM
VIA EPIA Mini ITX beeping problem tbdombrosky General Hardware Discussion 10 06-28-2002 11:31 PM
