Notices
Old 04-20-2008, 10:57 PM   #31
The1Architect's Avatar
Quote: Originally Posted by jimmler View Post
Architect,
NOW I understand the Valet switch. That's a good idea. I like it!
I don't know what to tell you on the power supply issue. Have you powered up the board with a known good power supply out of a desktop or such? If you're using the Opus for testing, do you have 12 volts at the main feed as well as at the ignition wire? Are there any led's on the Opus to indicate its status? Also try flipping the "power on" wire from the Opus to the motherboard. Some are sensitive to polarity and won't turn on if the polarity is backwards. Keep us posted!
ok so this is how i did it. i did try flipping the power switch (OPUS/MB). there is a led on th OPUS that is blinking every 13 sec. when i turn the switch on the led blinks right away even before 13 sec.
>> > Design & Planning . . . . . . . . . . . . . . . . . . . . 100%
> Software Installation . . . . . . . . . . . . . . . . . . . .98%
> Hardware Installation . . . . . . . . . . . 55%
>>> Overall Progress . . . . . . . . . . . . . . . . .85%
The1Architect is offline   Reply With Quote
Need: Startup/Shutdown Controller Suggestion for Morex PSU prospero Power Supplies 0 02-16-2006 02:48 PM
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 07:25 PM
M1-ATX 90W PSU Usefull Observations James141 Power Supplies 10 03-11-2005 09:25 AM
Mastero 3.5 12v-12v PSU KIT fs SteveC Classified Archive 0 09-28-2004 12:04 PM
Powering up normal ATX PSU KimaX Power Supplies 5 09-28-2004 01:08 AM
