Notices
Old 04-16-2008, 03:40 AM   #1
psu fried my mobo?
i have a opus 150watt psu and p3 computer. when i was hooking the psu to my mobo i started smelling a burnt smell and noticed the mobo's chip is burnt with a hole. it wasnt really a big deal i fried my mobo but i wonder if anyone know what happen. anyone have a clue? dont want to burn another mobo. bet it was a newbie mistake or something hahha
ibdatfo is offline   Reply With Quote
Old 04-16-2008, 01:02 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
We have no way of knowing what happened, to be honest.
If you connected everything correctly and all equipment is good, then the PSU was not the source of the motherboard frying like that.
My first thought is a short somewhere, but without seeing your setup, there's no way of knowing for certain.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 04-16-2008, 01:07 PM   #3
hmm... i connected the red wire to the battery and ground the black wire and hooked up the yelllow wire as remote wire to my ignition. then connected the 20 pin to a 24 pin harness and connected that to the mobo. did it sound like i did everything correctly?
Old 04-16-2008, 01:14 PM   #4
MySQL Error
MatrixPC's Avatar
Man I haven't hear that for a long long time. According to the process, you did everything correct. I know you didn't mention about the fuse, but I'm sure you do have one.
Something drop in the mobo? You know when you cut the wire, those little wire can drop in there and cause a short circuit.
Without connect to the mobo, short pin 13 and pin 14 on the ATX cable (20 pin) and check for voltage on that 20 pin. Make sure you have the pin out diagram to compare to make sure if pin 1 is actually pin 1 and not pin 2. I mean just double check for cross pin on the connector by error or mistake from manufactures, ...
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 04-16-2008, 01:24 PM   #5
yea i did have a fuse connected. yea i think i will check on that atx cable and see if everything is where it should be. kind of scared of getting antoher mobo and have the same issue..... loooking to get a via m10000
Old 04-16-2008, 01:30 PM   #6
hmmm i just remember! the 24 atx harness i got it from my personal computer and it was working fine. wouldnt that mean 24 atx harness should be working fine right?
Help me choose a Mobo and PSU Slightly_Stoopi General Hardware Discussion 1 04-29-2006 08:19 PM
Mobo or PSU? blackedoutxb Power Supplies 2 04-26-2006 10:53 AM
Ram fried PSU? lostreception General Hardware Discussion 11 05-28-2005 01:44 PM
Mobo Woes - Enlightenment needed nzKAOSnz Off Topic 0 05-17-2004 09:24 PM
What to look for in a PSU some info for you cproaudio Power Supplies 9 04-04-2003 02:07 AM
