Notices
Old 04-16-2008, 03:42 PM   #1
EaRNi's Avatar
M2-ATX to power Carputer and xbox 360?
ok, at the moment i have a M2-ATX and i am in the process of building a pc for my car, i have been thinking about putting my xbox into my car at some point in the near future.
my question is, will i be able to run my xbox 360 and my car pc through the same PSU?
also, is there a way to only ever have one or the other powered? never both at the same time!
what do i need?
EaRNi is offline   Reply With Quote
Old 04-16-2008, 07:07 PM   #2
I do not think the M2 has enough power to supply both, 160 Watts
Rick99TAWS6 is online now   Reply With Quote
Old 04-16-2008, 07:46 PM   #3
EaRNi's Avatar
thats what i mean, could i not put a switch in the M2 ATX so i can flick between pc and xbox 360? then technically i wouldnt be powering both.?
Old 04-16-2008, 08:23 PM   #4
Neither darque nor pervert
DarquePervert's Avatar
The engineering involved in pulling this off wouldn't be worth the additional expense of a second PSU...
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 04-16-2008, 11:22 PM   #5
JimmyFitz's Avatar
You would have to add a number of relays just to switch all the outputs. You would lose the intelligent startup and shutdown timing features that the carPC needs for smooth functioning. The cost of parts and time to make something that barely works would not be worthwhile. You can use a second (probably less expensive) supply for the xbox, and be able to use both units simultaneously.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 04-17-2008, 05:11 PM   #6
EaRNi's Avatar
cool, i will just do that then. thanks for your help
Using an xbox as carputer Shorty2301 Newbie 7 11-27-2007 09:41 PM
FT/FS Xbox 360 Premium will trade for Carputer Zeroaviation Classified Archive 8 09-03-2006 08:14 PM
TRADE: Xbox 360 for Carputer carfreak01 Classified Archive 44 03-31-2006 10:47 AM
The New XBOX 360 a new carputer sdashiki General Hardware Discussion 13 05-13-2005 12:56 AM
XBOX, Carputer, power Question! ELECTRIC GURUS HELP! EggrollXpress61 General Hardware Discussion 5 08-21-2004 12:15 AM
