Old 04-17-2008, 04:36 PM   #1
EaRNi's Avatar
m2 atx psu wiring ideas
ok, so i drive a lupo gti, the battery is in the boot, the PSU is going in the boot but i havnt got a clue where to pick up an ignition live.
i thought about taking one from behind where my stereo used to be to the boot but its quite a small cable and after hours of searching on here it seems i need a big cable or do i?
I already have a big cable coming from my battery to power my amp and the fuse is quite local to the PSU. could i just join in this fuse?
from reading some posts it seems the ignition live is simply a switch wire which has hardly any current running through it therefore, my method would be fine but i really dont want a car fire lol any help?
EaRNi is offline   Reply With Quote
Old 04-17-2008, 07:18 PM   #2
treetop777's Avatar
Nope, don't need a large wire nor a fuse. Not sure what you mean in the third paragraph - run constant 12v and switched 12v through the same fuse, is that what you are saying? if so, DON'T.
treetop777 is offline   Reply With Quote
Old 04-18-2008, 11:41 AM   #3
EaRNi's Avatar
no, i am saying i wouldnt need a seperate power supply from my battery, i can just join the permanant 12v into the fuse with the amp power? and then run a small cable to the front of my car to pick up an ignition live?
Newbish Wiring Question: OPUS as a "non-intelligent" PSU DJiK Power Supplies 3 09-14-2006 10:54 PM
110 VDC Input on a regular ATX PSU Jeeve5 Power Supplies 6 06-19-2006 02:28 AM
Standard Desktop ATX PSU Question... lowspeedchase Power Supplies 8 02-15-2006 09:04 AM
24VDC in ATX PSU Julian General Hardware Discussion 3 03-18-2001 05:26 AM
KeyPower DC-DC ATX PSU katnip General Hardware Discussion 4 08-08-2000 01:16 PM
