Notices
Old 04-18-2008, 10:18 PM   #1
m2-atx not coming one
hey i hope this isn't already been brought up but i haven't had much luck searching the problem i am having is if i jumper the atx connector it will turn on however it will not turn on anyother way if i manually trigger the MB it will not turn on the only way i can seam to get it turn on is to jumper the atx connector any help would be great
Thanks,
yonu
yonu is offline   Reply With Quote
Old 04-19-2008, 04:36 AM   #2
Raw Wave
Rob Withey's Avatar
what jumper settings? what you do have the ignition wire connected to? do you have the power switch wire from the m2atx to the motherboard connected, and the right way around?
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 04-19-2008, 09:23 AM   #3
ok right now i am using a bench supply and i have tryed it with and without the mb switch hooked up and at the moment i have the jumper set at the default settings
Old 04-19-2008, 06:51 PM   #4
ok i tryed switching the connectors for the mb switch and still no go it will only turn n if i jump the atx connector any advise would be great
thanks,
yonu
Old 04-20-2008, 10:20 AM   #5
I am hoping someone can make a suggestion as i hate to have to send it back and wait on a new one to get this thing installed
thanks Rob i checked what you talked about but no luck
thanks,
yonu
Old 04-20-2008, 10:59 AM   #6
Raw Wave
Rob Withey's Avatar
I have no more suggestions. You didn't really answer my question about the ignition wire, but if you checked it and it is good then nothing more to check.
Old 04-20-2008, 11:01 AM   #7
no the ignition wire is good as i am running it from a bench supply at the moment and boith wires are powered from the constant
Xbox w/ M2 ATX and PSU convertor MiniRX7 Power Supplies 1 11-25-2007 07:45 AM
M2 ATX Amp turn on not working CdRsKuLL Power Supplies 21 10-30-2007 10:31 AM
Another M2 ATX Problem mattfl Power Supplies 8 02-23-2006 05:47 PM
Powerin the LCD with the M2 atx luckyno LCD/Display 2 01-20-2006 02:14 PM
New ATX PS coming out dbinnc Power Supplies 33 01-26-2002 02:34 AM
