hey i hope this isn't already been brought up but i haven't had much luck searching the problem i am having is if i jumper the atx connector it will turn on however it will not turn on anyother way if i manually trigger the MB it will not turn on the only way i can seam to get it turn on is to jumper the atx connector any help would be great
what jumper settings? what you do have the ignition wire connected to? do you have the power switch wire from the m2atx to the motherboard connected, and the right way around?
ok right now i am using a bench supply and i have tryed it with and without the mb switch hooked up and at the moment i have the jumper set at the default settings
thanks Rob i checked what you talked about but no luck
I have no more suggestions. You didn't really answer my question about the ignition wire, but if you checked it and it is good then nothing more to check.
