Notices
Old 04-19-2008, 09:42 AM   #1
Desktop Power Supply Help
Okay, I have been searching around the board and trying to figure out what power supply that I need for my computer so I can put it into my car without a power inverter and that the computer can turn on and off when I turn the car on. What I have is a Compaq SR1023WM and from what I have looked up here is what it says about the motherboard
Motherboard Description MIS name: MS-6577 M-ATX Rev. 3.1 (Giovani), Rev. 4.0 (Giovani2)
Compaq name: Giovani-GL6, Giovani2-GL6
CPU Socket 478 for Intel P4 Williamette and Northwood processors
1.4GHZ to 2.8GHz or higher
Intel 845GV Chipset FSB 400/533
Multiplexed AGP interface
Integrated 3D/2D graphic core
Supports DDR 333/266/200 memory
Here is a link to more info about the computer
http://h10025.www1.hp.com/ewfrf/wc/d...product=411354
Would the M2-ATX or the M4-AtX work on this motherboard to run in the car. If anyone can help me with this I would greatly appreciate it. I do know about wiring things in cars but trying to rewire this computer to run off of 12v instead of 110 is something new to me other than putting in a power inverter and would like that to be my last option. Thanks again for any help anyone can give me.
kitt351 is offline   Reply With Quote
Old 04-22-2008, 07:04 PM   #2
Old pc much? Anyhew, I love the inverter route personally, I run a 1000W inverter in my cargo area with the pc plugged in and then route a power strip under the passenger seat for any and all sorts of stuffs including the touchscreen and usb hubs. Inverter even has a remote to it. Can also run stuff off it when car camping too which is nifty. Good quality inverters also have chassis grounds which eliminate near all noise from the system which is all the better. If you really wanna do it without an inverter, there is almost no way of knowing the power specs of that system without a watt meter. Plug this into your wall and then the computer into it and it will tell you how much you are using. The kill a watt I like personally because its just so easy to use (http://www.buy.com/retail/product.as...36&dcaid=17902)
Anyways, good luck!
That being said, EVERYTHING gives you cancer nowadays so live it up before your cornflakes give you malignant tumors.
Furian is offline   Reply With Quote
Motherboard + Power Supply question for mp3car experts denk Newbie 10 08-28-2007 11:10 AM
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
power inverter power supply shutdown problem launter Power Supplies 10 09-21-2005 12:12 PM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 01:13 PM
Power Supply Options? Optikal Power Supplies 9 06-26-2004 06:46 AM
